4 hours ago, DougFL said:
A software update for the Camera and Infotainment system was just released.  Check your Setting, About and you should have Build V509
Do they roll this out slowly?  I just checked for updates and it said No updates Available. V507 is what I have..
Mine just did an update 2 days ago, no idea what it updated as it doesn’t tell you but it sure didn’t update the nav or cam screen clarity.
My camera is very clear during the day, much clearer than my K2 was.  At night, it's a little grainy but not that bad.  I've actually had a friend comment on it saying "damn that's a clear camera".  I do have the IOS rpo code radio which is one of the top versions with HD rear camera.  Do u have the HD camera or the regular one?
Edited by z1boss
I would have no idea which camera I have, where would I go to find out?
What kind of truck is yours and do you have Convenience Package 2? You only get the the HD back up camera with convenience package 2 which comes with the better radio.  An easy way to check if you have convenience package 2 is if you have the power rear sliding window on your rear windshield.  If you do then you have the package, if not then you dont have it.
Edited by z1boss
I have a HC and I have the power sliding window.
Then yours should be the HD one.  Not sure why it's not clear.  Maybe you got a defective one or they installed the wrong one?  Only other thing I can think of is that it's a little dirty(like has some dust on it)  and maybe that's affecting the clarity.  Idk to be honest
Edited by z1boss
You can force the update if available.  Go to Settings and scroll down to Updates and then select Check for Updates.  It will tell you if an Update is available and give you the option to download.  Also, make sure you have selected to have Updates automatically downloaded.
Are the updates available even if you don’t subscribe to Onstar and don’t have the WiFi plan?
IDK either, it’s not dirty and when I went back to the dealer they took me out to 2 other trucks and their Back Cams looked the same as mine, we didn’t try the nav because the data cards weren’t installed. I drove a 14 HC Friday and both the nav and back up screens were better than my 19.
I am not sure, but logically, how could you get an update to your Truck without any Data connection.  Did you try setting up a WiFi Hotspot to your Home WiFi network or Phone?
Go into settings and ask it to update.  It will let you know.
Onstar is always connected to the truck whether you are subscribed or not..  Maybe it uses the same connection.
Edited by O Town Denali
I assume they roll it out like the Phone providers. My unit says no update available also. I just force update the unit every day to see if one is available.
I did, I used my phone for a hotspot but from what the screen said is the truck has to be off for it to update and once you turn the truck off the hotspot turns off. Maybe it’s alread downloaded but not installed? Who knows.
Go to Settings, System, About.  It will show the latest update.
    black cat
    black cat
  • Who's Online   3 Members, 0 Anonymous, 473 Guests (See full list)
