Replacing vacuum pump 2014 Sierra
Welder2014
Going to replace my vacuum pump with the new designed one. Has anyone removed the lower steering shaft to gain more access while doing his repair. Could doing this cause any damage to steering system? Looks like I could just remove the steering shaft knuckle for more clearance.  Thanks.
No problem. Just keep the steering wheel locked in place. It doesn't matter what  position wheel is, just keep it there.
I had no choice than to disconnect the steering shaft... getting to the bolts on the pump pretty much required it. Looking back, I should have done that first instead of fighting it.
Start your truck and rotate the steering so that the steering shaft bolt is easily accessable, then shut it down and lock the steering in place. Make sure that there isn't a bind between your tire position and steering, because once you take it loose, it's going to move on you. (Ask me how I know this. Oops.)
Thankfully, my wife was able to get into the truck and slowly rotate the steering wheel while I aligned it back into place for reassembly.
I also bought the little belt removal tool you'll need for the vacuum pump belt... but it sat a little high and got hung up on the aluminum housing above it. Rotating the crank with a large ratchet was fun... and the belt feel like it was slipping because the stupid belt removal tool wasn't allowing the pulley to continue to rotate. Your mileage may vary... but I hope you don't run into the same issue as I did.
On mine, there was a small wiring harness that ran under the pump (not connected to the pump, just ran under it) that required me to disconnect some lock down tabs to free it up. Taking the pump out required me to pull/rotate the pump forward towards the radiator, as the pump pulley was too big to pull it back towards the rear and fit through where the wiring harness was located.
I probably spent more time bitching about the GM Engineer that designed it that way than I did wrenching... definitely something that was designed to be installed on the assembly line easily without much thought towards ease of replacement. (Like a few other things on these trucks.)
I found a bit of metal/debris in the lower part of the opening where it bolts to the block. I used a magnet, then my finger, a rag, and some spray to try and get that crap out of there... didn't want it getting back into the engine.
Mark
go to the HOW TO SECTION and read sambone 95 write up on how to replace the pump i did mine without removing the steering shaft but i also have every tool known to man the hardest part is trying to use a torque wrench to tighten the bolts. if i had to do it again i would remove the steering shaft
Any sort of metal shaving is not good.
Hopefully the pumps failure did not release any of that into the oil system.
Have you done a recent oil change to check for shavings there?
Vacuum Pump failure is notorious for causing engine damage as well if it is not caught in time.
    BrandonFranceschi
    BrandonFranceschi
  • Who's Online   4 Members, 1 Anonymous, 1,531 Guests (See full list)
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
