Hey all.  I’m the proud new owner of a 2019 trail boss custom.  I want to purchase the LED headlights from Chevy, does anyone know if they are just plug and play?  I am assuming they should fit...but not positive.
Does anyone know?
thanks!
Edited by jrich58
I haven’t seen it done yet, but past experience with the previous generation would lead me to believe it’s not likely to be plug and play. GEN5DIY makes adapters but nothing for the ‘19s yet. I’m sure you know, but you’d need a new grill too as the LED headlight shape is different (smaller).
Does anyone know?
thanks!
Not sure if it is plug and play but the grill is completely different on the models with the LED lights as it wraps differently through the lights
The wiring harness, connectors and the fuse/ power requirements could also be different. You can check with the dealer to see if the part number on the wiring harness is the same, if so you could have some luck in the swap if they fit your existing grill/fender opening.
LED headlights?
The Up-level Silverado Trims have completely different head and turn signal housings with built in LED systems.
Your only option is to wait for an HID kit or throw some HID bulbs in your stock halogen sockets.
5 hours ago, Sierra Dan said:
LED headlights?
And be prepared to get flashed an awful lot. HID in standard housings is usually not good, and worse in a tall truck.
But really, I still got flashed often in my Sierra with OEM HID, and flashed a few times in the new rig with LEDs.
LOL...
I get flashed in my '14 Sierra with Stock Projectors and Silverstar Halogens.
Yeah, those non-DOT legal HID retrofit kits are terrible.  Xenon arcs have entirely different shapes (and resulting reflections) than standard halogen bulbs.
They are not cool for low beams.  For high beams.. whatever floats your boat I guess.
The most obnoxious offenders around me are the ones with LED light bars hanging on the front bumper on with the low beams.  On city streets with streetlights.
I guess they think they look cool. :shakehead:  Or maybe like the F-150 driver this morning with the tailgate sticker "Unapologetically American" lol.
Once in a blue moon I get flashed but who cares. I just flash back ?
curious if anyone has used led bulbs in the halogen housing on the new trail boss custom?  Would this be OK?  Void any type of warranty?
I did change my halogen with LED's in the halogen housing.  I have had them for 3 weeks now.  So far no issue.  I also changed out my halogen high beams with LED;s.  No issues at all.  it looks so much better.
Would you mind giving the link to that LED bulbs? Thank you!
Any pictures of what the low beams look like with the LED bulbs?
Edited by mpuleo
    ChristopherDobson
    ChristopherDobson
  • Who's Online   0 Members, 0 Anonymous, 1,122 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
