Hyperflash help
I have aftermarket LED tails.  We just got a ton of snow here in Washington state and now I have hyperflash...
so i got some resistors as the lights still work just stupid hyper.  Attached to green and black did one side only and still hyper flash.
Anyone have any ideas?  And yes I searched the forum and found nothing.
you need to put resistors on both sides to eliminate the hyper flash. When I had anzos they hyper flashed and swapped out both sides then problem solved
Lots of answers on the Internet. Most answers for issues when freezing outside is due to low quality LED’s.
Sent from above
Sweet.  Will do and see what happens
I'm going to try and get the dealer to flash my BCM to turn off the bulb out indicator (Which is hyperflash) so I don't have to worry about resistors but havent gotten a clear yes or no yet from anyone i've talked to. I've been told on a 2500 its easy but can't confirm its the same on 1500
How many ohms are your resistors? Do you have two turn signal bulbs in your tails originally? If so you need a resistor for each bulb that you originally had. 4 incandescent bulbs = 4 resistors
Sent from my SM-N950U using Tapatalk
1500 has 3 lights per tail.  1 brake 1 turn and 1 reverse.
I have resistor in everything but the reverse
59w 20ohms
    overspeed
    overspeed
  • Who's Online   2 Members, 0 Anonymous, 305 Guests (See full list)
