On 11/23/2019 at 9:11 AM, 19ShadowCustom said:
I think it was an early production issue, my 19 Custom has SXM and Onstar
Yes, In the build options for a Custom, you can get a Convenience Package that has XM included. And you can get the Havana Brown. This is only for the larger models. I work in the trades and need the 8' bed, and there are no options like this available. The smaller bed is useless to me.
Edited by Tony D
added content
On 2/11/2019 at 1:57 PM, jlong1984 said:
I've seen LT and RST trucks without Bose that did have SXM. Not sure how they were optioned in order to get SXM.
My 2019 Trail Boss "Custom" has it. Nothing fancy in my radio setup, but I believe the Sirius XM configuration came with the  $275.00 "Infotainment Package" that I have.
my truck has the Custom Value package. includes, remote start, SXM, OnStar, LED lighting, Bed lights, Trailering package, Power Tailgate.
That sounds nice. If they would add that option to the regular cabs that would be great.
Edited by Tony D
added content
  • 9 months later...
Sad.  I've seen 10 year + RAM wok trucks with the satellite radio.  You would think making it standard would make the manufacture plenty of money from Sirius/XM
I have a build sheet for the 2021's and XM is there.?
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
