flipmode815 Posted February 20, 2019 Posted February 20, 2019 I'm in the market for a aftermarket intake manifold + throttle body, anyone know the best ones or where to look. 2014 Silverado 5.3L
Nitrousbird Posted February 20, 2019 Posted February 20, 2019 What are your supporting mods. If stock or near it, worthless. TB in general isn't a great upgrade from my research but porting the stock intake manifold can be.
VdellaV Posted February 20, 2019 Posted February 20, 2019 Not worth it, Stock GM Manifolds are great and aftermarket ones have been proven to be even worse, specially for stockish engines. Not even worth it to upgrade to a 6.2 manifold/TB Having said that, i´ve heard about this brand of intake manifolds called Whipple. They even come with a belt driven thingy that makes meow meow and choo choo noises, but they are like 6k dollars
1SLOW1500 Posted February 20, 2019 Posted February 20, 2019 The 6.2 intake and tb are great mods and improve power. It has been tested and it works. However this is after supporting mods and changing the tune so it knows the right manifold volume.For the cost it is worth it. Don't worry about porting the tb the 6.2 is larger and you will not see increase in that alone that is. More for us supercharger and turbo guys.There are post with dyno numbers and how to. Sent from my SM-N960U using Tapatalk
flipmode815 Posted February 20, 2019 Author Posted February 20, 2019 Mods I currently have are, kooks long tube headers with 3" y pipe, cat back exhaust, air intake, pedal commander, and afm disabler. I have a cam waiting to be installed but was wanting to do intake manifold and tb with it so I only had to tune once.
1SLOW1500 Posted February 20, 2019 Posted February 20, 2019 Mods I currently have are, kooks long tube headers with 3" y pipe, cat back exhaust, air intake, pedal commander, and afm disabler. I have a cam waiting to be installed but was wanting to do intake manifold and tb with it so I only had to tune once.And you are a 5.3 then Dd 6.2 intake and throttle body. You need to change tune for larger intake and the re cal. For tb. But yes 100% it will help performance. Do it and for the $120 it is the cheapest power mod in your combo. Sent from my SM-N960U using Tapatalk
HeathT-87 Posted February 20, 2019 Posted February 20, 2019 Seems a bit pricey but I have been thinking about it. https://gwatneyperformance.com/product/gpi-di-5-3-engine-air-induction-package-2014-up-gm-truck/#configuration
1SLOW1500 Posted February 20, 2019 Posted February 20, 2019 Seems a bit pricey but I have been thinking about it. https://gwatneyperformance.com/product/gpi-di-5-3-engine-air-induction-package-2014-up-gm-truck/#configurationThat price is crazy get 0art numbers and look up should be less that $150 each. Sent from my SM-N960U using Tapatalk
