I did a quick search but didn't find anything really similar.
I have a 2018 Sierra I got a couple months ago.  This is my first experience with a capless fuel system as my previous truck was a 2015 Sierra.  Twice so far I've had substantial overflow when fueling up at two different gas stations.  I'm very careful when filling up and I fully insert the nozzle and pump only to the first click indicating it's full.  That's where the problem seems to be.  At that click gas spills out and then down the side of my truck.  I've had to thoroughly wash and wax the area twice now and it's becoming pretty annoying.  Not to mention I don't want any paint damage.
Does anyone have any thoughts as to why this might be happening?  Am I doing something wrong?  Thanks.
Were the overflow incidences at the same pump? If you're putting the nozzle in all the way, it's going to be the nozzle's fault if it overflows on/prior to the first click. I have a 17 with 35k and don't think I've ever had an overfill.
Thanks for the reply.  They were at different gas stations.
Welcome to the site. Others have mentioned to put the nozzle in all the way, and then "back it out" a half inch or so, and it stops happening.
I had spills with the capless system on my first few fills too. The nozzle has to be just so as others mentioned. I also leave it for an extra 30 or so seconds after filling before removing. It seemed to me to be fuel in the hose that spills out upon removing rather then over filling.
  • 1 year later...
I have a 2019 Sierra 1500.  I have the same issue with gas spewing out when filling.  If I am lucky enough to be able to hear the tank filling, I can stop it from happening.  If filling at slow speed, it helps but still spews some fuel.  Maddening.
    smandy
    smandy
  • Who's Online   4 Members, 0 Anonymous, 514 Guests (See full list)
    • Holy s**t - not much of a parts thrower you say? You BLASTED that thing with the parts cannon!  You'd have been probably $1,000 ahead if you had just brought it to a competent shop rather than shotgunning a bunch of parts it clearly didn't need.   Just FYI - oil additives are really, REALLY good at ONE thing ... and that's emptying your wallet. They're ALL useless gimmicks.   If that has the L94 or L99, then #7 is an AFM cylinder. I'd suspect a failed lifter in that case.   If you leaned on wiring, sensors, and/or connectors while changing the oil, you'll have to check all that to be sure pins didn't get pulled out, connectors broken, etc.. Old wire loom that was barely adequate when new is certainly brittle by year 19 - make sure wires aren't chaffed and shorting out somewhere where you might have leaned. or supported yourself on it.   If your a mechanic, why didn't you just find out what you were missing and troubleshoot from there??  TIMED spark, fuel PSI / injector pulse, air, compression.  Can't make ANY money going the parts cannon route.
    • LOL! Are you joking?? That wax SUCKS! 100% gimmick made to "look" good.    After just TWO winters I had severe surface rusting in patches over 90% of the frame. Only reason it looks great in the pics is because I SATURATED the frame every single fall with used motor oil for 14 of the 16 years I owned it. Otherwise it would've been sent to the crusher 8 years earlier with the speed it was rusting prior!    I sold that POS 3 years ago. Was a gigantic headache the second it rolled off the showroom floor. Brakes pulsated on the TEST DRIVE. Door trim fell off the 1st week! Interior squeaked and rattled, and the drivetrain clunked after 2k miles. 4x4 switch failed shortly after. Front end - ball joints, struts, hub bearings - all failed between 38k-50k. Engine started burning oil at 50k. Rear and and transmission failed before 100k. Nothing but problems, and frustration with the piss-poor engineering designed to make you give up. Well, it worked! Nothing on that truck was easy to remove ... except the wheels. They haven't figured out how to screw that up yet. Give 'em time ...   I won't make that mistake again. EVER.   Such fond memories ... https://postimg.cc/K1qf23tS  https://postimg.cc/gallery/X02z64J  https://postimg.cc/gallery/mHSRXZv  https://postimg.cc/gallery/D4mMRfL
    • Different monitors do their test only under conditions specific to that monitor.  you MIGHT find the drive cycle conditions for the monitor that isn't ready on this site: https://lemon-manuals.la/   If it's not there, then it should be on alldata.com for your truck, but it requires a paid subscription.   And you need to know which specific monitor isn't ready.
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
