So never did a forum before so hopefully not starting it wrong. I’m looking for some thoughts on issue I’m having with my 2017 Silverado z71 crew cab after 4/6 drop issue is a grinding like noise only on highway maybe 60 mph and up just when coasting it doesn’t last long and seems to take about 10 minutes or so to start doing it. I raised tranny mount 3/8 inch and helped but still not completely right plus think it’s creating vibration is situate was t there without the shim. I know there’s lots of info on driveline angle issues on lowered and lifted trucks but seems it’s all on vibrations and not a noise like I have I’m currently trying to measure my angles to see what I have. I seem to have plenty of room for yoke in tailshaft so not sure it’s botttoming out. Thanks for any help
  • Replies 43
Top Posters In This Topic
Drive shaft on floor. Of truck. Maybe. Slide under and see. Where it is hitting. Then at. Least get a. Air bag helper. Worlds of difference.
Thanks I wish that was that was the  case but seem to have plenty of room everywhere pretty sure my drive angles are off just weird I haven’t found anything about this issue. I’ve been checking everything with suspension loaded I think driveshaft clearance issues is usually after 8 inches and more
I’m not sure exactly what axle wrap is I’ve heard of it
Angles can be in spec of each other but when you hit the gas or under driving load the operating angle jumps many degrees. Adds a stress on joints and bad for the pinion.
Zero and in some suspension - 1* is the loaded ride height. Or like me traction bars.
I can push the drive shaft forward about an inch and half wilth suspension loaded so seems ok I will admit the sound it makes sounds like maybe if it bottomed out against the bearing  It also seems little worse when warmer outside we have crazy weather so one day it’s 20 degrees next day it’s 40-50. Raising the tranny definitely helped so that also makes me think it’s in the angles I have a 4 degree shim for axle ordered them I will see what effect that has
I was thinking most people needed to shim the rear axle down to get correct angle but since my tranny is around five degrees down and axle is 2 degrees up I may need to shim my axle up more to get closer to 5 degrees up to match the front just feels wrong cause thought guys usually set rear pinion down a little to have a good angle when under load but if I shim mine down the rear would be down just like the transmission
Axle should be zero or negative do to the axle wrap and oil to the pinion. Then correct the trans. Other option that in my opinion is a great mod for all of us is new small diameter 2 piece drive shaft then you can set it to anything you like and go lower also. These trucks have super week shafts and the large diameter can also hit the body.
thanks I am planning to try 4 degrees down on axle this weekend the part that was confusing me is after my axle is maybe little negative down then I I won’t have opposite angles since transmission is down and not enough room to make it have upward angle and everything I read says you want opposite angles between the two and I’ll have tranny down and axle down a little
    • www.enginelabs.com/news/what-i-learned-today-bearing-clearances-vs-oil-viscosities/
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
