Leather Cleaners/Protectants?
DenaliAJ
Im wandering what is a good Leather Cleaner and a really good Protectant.  Ive seen too many GM trucks with Faded or Cracked leather relatively early in their lives and I really want to avoid it, any suggestions?
I've used Lexol Leather Cleaner and Protectant.  Works great.  I've used them on 2 seven year old cars with leather and have no problems.  Hyde Food is recommended by Rolls Royce, but is really hard to find. :D
I used Zaino 9 and 10 (leather cleaner, leather protectant) on mine about two weeks ago.  Still smells good (close to new leather).  It doesn't leave the leather greasy or slick (except for the first day.....and my butt didn't wear it off! )  :D  Sorry, haven't really put it through a good test.  It's a new 2001 truck, first time I used a leather conditioner.  ??? I love it though so far.  I also like it because it doesn't leave a gloss on the leather.  I'm sure there are others here who use it, and will back up the long-gevity of it.
My truck's a 95 and its leather is in perfect condition.  I put Meguairs Gold Class cleaner and protetant on every few months.  Just put some on a clean towel and rub it into the seats, it says to rub it off right away with a clean towel but I let it sit on and soak in for about 10 minutes and it does a great job.
Joe
Eagle One leather cleaner and then Eagle One leather Conditioner.
I just did the truck a few weekends ago and did the Aurora this past Monday night and now it looks supple and healthy again.
But it comes down to how well you clean it first.  Plus I wouldn't use an all in one cleaner/conditioner.
The Eagle one cleaner is a spray on cleaner.  I also use a stiff bristle brush to get into the nooks and crannies of the seat and then wipe it dry.
The conditioner is a lotion that you apply with your bare hands, let sit for awhile (overnight is the best) and then wipe off with a rag.
I agree with siume99! The Zaino product is great. Especially for older cars, the leather smell brings the interior back to life! I have also heard real good things about the Lexol product, but I have never tried it myself!
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
