Where is my Motor leaking from
I have an 03 Silverado 1500 with 4.8 vortec and right above where oil filter mounts I have oil leaking around 2 “plugs”? Needing more info on them and what to do to stop the leak! Thanks pic attached
Picture is a little odd. . But I believe that is where the optional oil cooler pipes would attach. There is a gasket located there to seal the plate that covers the two holes.
^^^^^^ This and make sure oil is not traveling down from above, oil sensor.
Thanks for the Info! Guess time for a oil change and to fix them gaskets. What’s the oil sensor look like? I’m no mechanic by any means lol just know the basics
The left circle should be the block heater plug, as your truck doesn't have one. It just looks wet around that. The right circle is hard to tell.
Honestly I'd do an oil change and then clean the piss out of the bottom side of the engine. It is so much easier to tell where the leak is really coming from when everything is clean. Do that and go hot rod the truck for a bit or just do your normal day to day driving for a few days and check on it when you get home. If you see it seeping, then you'll know where to start.
Like the users above said. The oil cooler bypass plate gasket looks like it is leaking. I would replace the oil pan gasket and the oil cooler bypass plate gasket at the same time. Very easy to do and there are 1000 videos of it on Youtube.
Oil Pan Gasket - https://amzn.to/2Y52dO0
Oil Cooler Gasket - https://amzn.to/2OgR3kM
    JJ_Denali2020
    JJ_Denali2020
  • Who's Online   1 Member, 0 Anonymous, 344 Guests (See full list)
