..I want to access the area behind the rear trim panel on my centre console.. maybe those that have done the console swap can help me with how to remove the rear trim panel?.. I am hoping it is not attached from the inside and I won't have to pull the entire console.. any exploded view parts listings I have seen only show these individually and not how they attach.. I've tried searching the console swap threads for pics but came up empty.
T15 screws are hidden in the rear peice. I think theres 4 of them
..  I did find the screws in the cubby area and removed them but I wasnt able to remove the rear trim panel ..I even tried some force with a trim tool but still it holds on.. am I missing something?
Edited by STRMTRPR
There is 2 more same area. I just dont quite remember where theyre at
.. awesome.. thanks for the help Nasty :thumbs:.. the other 2 were above them at the very top of the cubby
.. there were a total of 4...2 behind the rubber insert and 2 directly above the first pair at the very top of the cubby
i know i'm a little late to the party....but for others wanting some pics....
i added a little LED to the back cubby.....
..LOL that's awesome.. that's exactly what I did as well to both the upper and lower cubby.. I just tapped power from the socket
  • 2 years later...
STRMTRPR and bc-Chris,
I want to replace that 12v outlet with a hardwired 12v fast charging dual USB outlet.  I have a 2018 with center console and have removed those four torx screws but cannot get that rear trim panel to budge.  Did you use a pry tool?  How much force is needed?  Any tips will be greatly appreciated!
Thanks!19FBA8B3-3A28-4224-86CE-DD7002C1A5C0.thumb.jpeg.f1166e91c1fe28c31205b6138bd5fabf.jpeg
That's my original plan, plus adding an additional set of USBs on the other side of the pocket.
  • 6 months later...
I am looking to do the same thing. Also with the front usb ports.
Have you do this project yet?
Also what usb port are you planning on installing?
Silverado1475,
I was able to complete this project.  I added one in the rear portion of the console, it has 2 usb-3 and one USB-c ports.  Here is what I used.  $15.89 on Amazon.  works perfectly, backseat riders love it and was a clean finish.  Only difficult part was pulling off the rear face of the console.  It takes ALOT of force-you just have to keep working with it and pull up at about a 20degree angle towards the back seat.
56W USB C Car Charger Socket, Ouffun Aluminum Metal 12V-24V Multiple USB Outlet 20W PD USB-C & Two QC3.0 Ports with Power Switch Fast Car Adapter for Car Boat Marine Truck Golf RV Motorcycle
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
