27 minutes ago, TXGREEK said:
I’m all about clean burn, will I be able to use super and e85 if I converted/switched?
Sent from above
You can run it now even if you are not FF.  My 2002 isn't and I run it with no problems.  I don't get the performance benefit but I do get the clean burning as well as the higher octane.  I usually run a 50/50 mix in the winter since it does tend to start harder at temps below 38°F.    I have been running it now for 3 years with no issues.
I’ve got a 100K extended warranty on my 6.2 and don’t want to deal with reprogramming the ECM. I may go put $10 worth tonight heehee
Sent from above
Maybe this is a question for Karnut, he’s very familiar with E85.
Can you run 20-50% E85 in a 5.3 and 6.2 without retuning your ECM??
Sent from above
The “Flex” in Flex Fuel means it’s flexible and able to burn regular fuel and ethanol
5 minutes ago, TXGREEK said:
Maybe this is a question for Karnut, his very familiar with E85. Can you run 20-50% E85 without retuning your ECM??
Sent from above
Yes. The flex fuel sensor reads the alcohol content and automatically adjust the tune for it.
I know that, can it be mixed in with super or regular without being flex fuel?
Sent from above
Ok, I’m going to give it a shot in about an hour
Sent from above
Sent from above
Yes  I mix it all the time.  No issues.
Sent from above
Yes. But there is no point. You either run gas or E85. No need to blend fuels.
Only reason to blend is if your fuel system couldn’t handle a high percentage of E
Edited by Jacoby
I’d like to just run e85 whenever but I don’t have a 6.2 flex fuel kit yet and the question was if I need a conversion kit for my 6.2 before I can run E85?
Sent from above
Sent from above
Wait my reply to you was if you had a flex fuel capable vehicle. If you don’t then running E85 is a complete waste of money and will hurt the performance of your truck
Sent from above
Yes you need one. It’s absolutely pointless to run it if the ecm won’t adjust. There is no benefit at all. It will actually hurt your performance.
That’s what I wanted to know. Black02silverado says he uses it in his older 6.2 all the time with zero issues hmmmm
Sent from above
I ran E-85 in my 14 because it came capable and using it would give additional HP. It seemed to like it and I could get it cheaper that reg sometimes definitely cheaper than premium. I would usually tune my truck for premium and get the boost in performance that way. I did tune the transmission and turned off the cylinder deactivation. I did raise the shift points and RPMs and set the transmission at 50 percent TM. Every thing I’ve read says don’t put E-85 in a non flex fuel vehicle.
Appreciate it! Looks like I’m staying for Chinese tonight.
Sent from above
    1981dustin
    1981dustin
  • Who's Online   3 Members, 0 Anonymous, 1,463 Guests (See full list)
