Car play
Is anyone else’s car play maps sluggish and or the map wanders, doesn’t stay in the lane? Any fixes or recommendations? Takes fore ever to re-route and sometimes is wont even re-route me just stays in the same spot on all app (waze,apple,google maps Truck is a 2017 high country
Mine did this the last time I used it. It would stay off to the side of the road then a couple miles down the road would reroute to side streets I wasn’t even on or near and then it would catch back up. Did it a couple of times. I was way out in the country though. Not sure if that had anything to do with it or not.
That would be an issue with your phone GPS.  When it does that set it up on the dash and see if it clears up/works better.
Got a new phone and same problem but having it on the dash seems to be the fix thanks fellas
Do you live in an area where you have a poor signal?  I have an iPhone X, I can plug it in and put it in the compartment in the armrest and I never have any issues with maps.
I get decent service ive tested it all over so cal and it has been the same just as soon as i put it on the dash it re-routes and fixes it self immediately im on iphone xs on ATT
You might want to take the whole rig to an AT&T store and have them look at it.  There are apparently compass calibrations that can be done but I can't see that doing it would change what you are seeing.
I will look into that thanks for the input[emoji1303]
1 hour ago, dsm1995gst said:
Somewhat unrelated, but has anyone heard if GM is going to update the software so we can use CarPlay over Bluetooth?
Wireless carplay is Wi-Fi, not bluetooth.  BT is used to authenticate the connection and 'handshake', then it switches to a Wi-Fi connection for more bandwidth.
Dump Apple, move to Android, never look back.
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
