Bushwhacker Trail Armor
Haven’t seen them before. If you do them you’ll have to post some pics for us. ?
I think if I was going to do these I would want to see the directions before I ordered them though cause I’d be curious about the screws in the seam? I tried to look on Bushwhackers site and the instructions aren’t available yet.
For my 015 it did list 2 different numbers for the crew cabs not sure what the difference is as one set only said “coming soon”
I have not seen these before but it seems like you could just rhino line it for cheaper and not have to drill into your door skin. If I was going that route I would just line it and call it a day. Just my 2 Lincolns.
Sent via my cellular device utilizing a chat forum thingy!
Description says no drill. Typing the part number  online, instructions come up and they are held on with double sided tape. - BW14065.pdf
If you just want door sill plates, Putco offers them for the K2 trucks.
On the hole two reviews this has gotten, no one mentioned screws. Only thing mentioned was 3m tape. ?‍♂️
I do like the door sill portion for sure.
 Linex for the rockers or as they call it “chip guarding” starts at $1500 FYI.
Wow didn’t think it would’ve costed that much for bed liner. It’s been awhile since I’ve had any done. Like Penguin stated, I too would be worried about the rust portion. Although living in AZ I don’t have to worry about that. What about the moisture or dirt breaking down the tape and they fall off going 70 mph down the highway? Not trying to put you or the product down. I’m just playing devils advocate. I would like to know how this product holds up.
    President Roberto
    President Roberto
  • Who's Online   0 Members, 0 Anonymous, 270 Guests (See full list)
