Tire Suggestion 305/55r20 or 33x12.50
Ok, trying to decide which tire would be best to go with the 33x12.50r20 or the 305/55r20?  I am looking at the Nitto Ridge Grappler and the 33" are 32.76"x12.5" and the 305 tires is 33.23"x12.44" .  The tread depth is 18 on the 33 and 16 on the 305.  I have been really looking at the 305/55 as it was slight larger and basically the same width.  But it seems most everyone is going with the 33x12.50.  I asked on FB and they seem to say because the 33 has more tread depth the ride quaility is better, is this true?  Should I stay away from the 305/55 if I am looking for the best ride quality?  Which would you choose and why?
I'm running the 305/55R20 but my tread depth is 20.5 (Mickey Thompson MTZ).  Is your Trailboss leveled?  Mine do rub a touch but other than that I absolutely love them.
So I have bought the motofab 1” and 1.5” lift.  I think I am going to try the 1” and see how it fits and what it looks like as far as angles etc.  if the tire shop and I are both satisfied I will keep it on.  I am looking to go 305/55r20 with a 20x10 -18.  But after seeing everyone is using the 33x12.50 I am second guessing my tire decision.  I’m doing the lift and everything this week, so just trying to make my final decision on which way to go.  The guy on FB scared me when he talked about he tread depth and smoother ride.  I don’t want to put new tires on and have a worse ride than stock.  Also, truck is pavement only, I won’t be off roading, worst place would be the beach lol.  I liked the 305 as it was slightly larger.  The 33x12.50 at a height of 32.76” is just barely bigger than stock tire.
If it's the same tire, I honestly dont think your gonna notice much of a ride difference between the two sizes and tread depths because the differences are minimal
If they’re comparable tires, then the extra tread depth should yield a few more miles  before wear out. If they are close to rubbing at all, I would go with the smaller. Remember, when you’re looking at wheel well clearance, you’re doing it static. Your suspension is dynamic. If it’s close parked, then the suspension travel will cause impact when it gets compressed, especially if turning. Don’t carve up your new rubber with sheet metal. Lastly, price is king. Which is cheaper and has better warranty? That would decide for me, if everything else is equal. You’ll not be able to tell the difference in the two tires sizes if they’re  the same model. Also, is one ten ply? If so, pick the ten ply. Just my .02 cents.
Unfortunately Nitto does not provide a warranty on tires.  Both the 305/55 and the 33” tires are F load 12 ply tires.  I am adding a 1” lift so neither tire should rub, or at least that’s the plan!
I buy tires from Discount tire. I’ve had good luck lately with TA KO 2 they “good will” mileage warranty them for me, there. But, I’m also a couple of decades in with one tire shop, so I get a little bit of preferential treatment once in a while. The last NITTOs I tried, I removed after a week. For me, they didn’t handle well. But, that’s just “for me” your findings may vary wildly from mine.
the other thing I’ll add is that, if Lifetime balance and rotation is an option, it is well worth the added cost. Especially if you can get it rolled into the deal. It is very nice to drop your truck off for a couple of hours and get it back with freshly road force balanced wheels for free.
You can get the 305/55/20 ridge grappler in a sl rating its a lot lighter than the lt.
Will 33x12.5x20 Ridge Grapplers fit on the stock wheels workout any modifications?
Sent from my Pixel 2 XL using Tapatalk
Yes they will fit but you may rub on uca and swaybar. If you have stamped steel a arms they may not work.
I'm getting the AT4 with the 2" factory lift. I'm guessing that has the aluminum ones
Ok I didn’t realize it was a 19. You should be good then
    • HD at the moment, are kinda their own deal.  How LTZ sells on those vs on 1500, there is a difference.   They are merging most of the mid trims on 1500.  LT, RST and LTZ are replaced by one trim, Silverado.  LT and RST are a BIG portion of sales.    Bad naming choice aside, the new Silverado trim will offer the spread of options that those three trims offered.  So expect to see things like the tech package for example, and maybe memory seats.  And LT Trail Boss will now just be "Trail Boss" (formerly LT Trail Boss) but will offer content spread like the new Silverado trim will.  The press photos showed the Trail Boss (formerly LT Trail Boss) has access to Super Cruise now, which on the current truck was High Country only.
    • I installed a Hellwig rear sway bar on my 21 Sierra SLT, it made a huge difference on how the truck handles, no body roll, the trucks much more planted now. Not sure of the suspension differences between the 21 and 26,  if its body roll your having a sway bar will solve it.
    • So a follow up and my fix. I found in online searches the live data to look at on a scan tool to verify the fuel tank pressure sensor was working.  It showed an spec number towards the lower end of the rang, but in spec.  Then while it was running opened the gas cap and the pressure should change.  It didn't change even a tiny bit.  The data for the purge valve said it was open...never changed. So then I measured the voltages on the plug for the fuel pressure sensor and they matched what it should be.  So local car quest parts had the sensor in stock...it was a bit of a pain to remove and an even bigger one to get it to actually go back in.  It helped to unbolt the driveshaft and bungie cord away from the gas tank to give a bit more room to work. So fuel tank pressure sensor in I cleared the code, and started it up.  I went to the scan tool's live data and... Eureka! The pressure number was different and fluctuated a bit.  So took it on a short drive and pressure number varied saw the purge valve go from closed to open and back to closed.  Drove it to and from work for roughly a week plugged in the scan tool no codes.  I took it in to get tested and passed.  In my state's infinite wisdom (oops meant greed), since I pushed the test with the maximum extensions I have to take it back in by Feb '27 to 'get it back up to date', then my next test won't be until Feb '29.
    • Any grease on the stud threads of any kind?   Wheel studs should have NOTHING on them for proper torquing and so the nuts don't back off.     Are all of the mating surfaces clean?  So wheel, rotor and hub?     We've had plenty of trucks at work with that wheel, this is a first to me.  Makes me think they've got a lube tech putting anti-seize on all the wheel studs or some kind of grease, and they need to stop doing that.  To have 11 other trucks with the same exact problem.
    • I was a Chevy guy for years, then switched to GMC because I liked the looks better.  I'm actually thinking I like the Chevy looks better than GMC for the first time in a lot of years.   One thing I know for certain, the new GMC dash is hideous!  Chevy wins this one!
