Started up the truck after work and instantly heard the cooling fan turning and sounded like it stayed engaged the whole way home then the check engine light came on taking it in tomorrow so this makes the second brand new Chevrolet truck I have bought and less the 1k mikes something is wrong ?
Well it was confirmed fan clutch is locked up they say the have to change the clutch and relay why both I don’t know
It'll be fixed and back in your hands soon.  Could be worse.  That said, always a bummer when a new ride fails...
What did I get myself into. First gym purchase since 1986. Brand new Sierra for $60k and the thing starts to implode with 3000 miles on it. Brake pedal switch which enables push button start crapped out. Really GM. Holiday weekend to boot. Now what. How quickly can I get a do over?
well what were you expecting.  You only paid $60,000 instead of $90,000.
kidding aside, hopefully that's all you really have to deal with for now.
    • Some clarification may help with some of these issues.   - Rev Industries is/was the division of BAK (now Realtruck) that makes covers under the OEM names.  So if you see one with a Ford logo on it, or if you are buying the GM Accessories cover, you are essentially buying a BAK G2 cover with different branding.   - Rev Industries now markets under RealTruck "Advantage."   - As of May 1, 2025, the Advantage covers now have a 5 year warranty.  Anything before that was a 36/36K warranty.   - Parts for the covers are available from Realtruck or BAK.  The email address to reach them is [email protected] or you can call them at 818-365-9000   - If the entire cover has to be replaced, you have to go through your local GM dealer.  Service dept opens an RO, notes the damage and submits it as a warranty claim.  Keep your paperwork handy so they can confirm when you purchased it and it's within the warranty timeframe.  Once the warranty claim is approved, Parts orders the replacement cover.  When it arrives at the dealership, service will remove and install the new one for free as labor is included under warranty.   - The Advantage covers are not the latest and greatest Gen 3 covers.  They still use the old school clamps, elevator bolts, etc...If you want the newer technology, consider buying your cover in the aftermarket world.  That way, if you have an issue you can deal directly with the manufacturer.   - Finally, RealTruck has a program with many of their authorized dealers that doubles the warranty to 10 years if the authorized dealer does the install.     Hope this helps.
    • Welcome to the group!  My '22 just crossed 150K miles.  Runs perfectly.  Oil pump belt will be done in the next 30 days or so and onward hopefully for another 150K.  Love the truck.
