Does anyone have a spreadsheet with all the torque specs for these T1 trucks (I.e. leaf springs, lug nuts, sway bar links, etc)? I know there are several threads on the K2 trucks... would like to do a once over in my 19 now that it’s nearing 5k.
Anyone???
I'm changing my rear spring blocks and not sure of the u-bolt torque.
I heard that the factory U-bolts are really a one time use kind of thing. When I changed the blocks on my K2 truck, I bought a set of Zone grade 8 u-bolts. Much beefier and made me feel better about the taller blocks.
Rear Spring U-bolt Nut [4x]
Caution: Refer to Fastener Caution
Caution: This vehicle is equipped with torque-to-yield or single use fasteners. Install a NEW torque-to-yield or single use fastener when installing this component. Failure to replace the torque-to-yield or single use fastener could cause damage to the vehicle or component.
Procedure
  1. Remove and DISCARD the rear leaf spring U-bolt nuts. Replace with NEW only.
  2. Install NEW nuts. Do NOT reuse old nuts.
Procedure
Thanks - good to know.
What do you torque the new ones to?
Rear Leaf Spring U-Bolt Nut (1500)
First Pass:  80 nm (59 lb ft)
Second Pass:    Loosen 180 degrees
Third Pass:    80 nm (59 lb ft)
Final Pass:    120–140 degrees
Perfect - thanks
    • 3.59 Kroger’s in Montgomery Tx. 20 cents higher than most around here. Very unusual. Saturday they were 3.49.
    • Starting at 17 running parts for my father’s construction business to haul our equipment. Eventually doing shows, sales and training after purchase. I drove a minimum of 50K miles a year. Half hauling something. After retiring 30K miles a year to the last 2 years 15K miles a year. 2/3rds highway driving. The major contribution to fatigue for me is from anticipation and awareness. I just don’t relax. Too many idiots on the road. There’s two kinds. The group that never leave the left lane tied together afraid to let anyone in doing 80. They’re mostly on weekends. Then the left lane sleepers usually next to a tractor trailer not advancing. Eventually the tractor trailer will drift over the sleeper will wake up. The train moves and the tailgaters who are usually mad as hell. You definitely don’t want to mix with them. The tail wagging bumper puller’s with under powered trucks are holding the tractor trailer up. That bunch are dangerous. I usually pace ahead all that. Unless there’s a gap when I can chill and let the speeders pass. I tried all different types of driving. I stay to the right except to pass, it’s the law that’s getting in forced more now because of road rage. I was so happy when my wife didn’t want to do the camping life. I had enough of pulling for work. The family has a bus and fifth wheel. I haven’t driven either one since retiring. No thanks.
    • Yesterday a suggested youtube video thumbnail caught my attention so I watched through it and it was a bunch of short clips someone gathered together of people pulling trailers, a lot of them were bumper pull holiday trailers and a pickup or suv pulling it. a few fifth wheels as well, some motorhome crashes also. The tail wagging the dog theme was quite evident in numerous self inflicted accidents that took out vehicles around them sometimes in the process as the unit finally swung around and flipped over in the middle of the highway. Or the other classic which literally could be called "I forgot the trailer was back there" in passing another vehicle on a multi lane one way freeway and then cutting back in line before the back of the rv trailer had passed the front of the passed vehicle and often in front of a tractor trailer and that never ended well. Or the wide kick out swing of the rear of a long travel trailer as they have so much overhang behind the axles and the trailer smashes into the side of vehicles in the next lane over ( typically sharp turns in city driving ). It makes one leery for good reason to be near an RV trailer after watching a video like that and be it on the highway, in town, or at a gas station where that rear end comes swinging around due to the fuel station being so cramped and not intended for larger trailers. I wonder how many officers have heard those words though "I forgot it was back there" as they investigate the accident LOL.
    • $5.10 for regular at the Kroger   It's been 6 months... is this the "new normal" ?
    • Just because a person can buy a travel trailer or a motorhome doesn't mean they can drive it properly. My observation during my RVing years.
