How to remove L86/6.2 engine cover
kennerz
OK, looking for a response from someone that has actually done this. It's not just remove the 4 bolts. There at least three push clips or something of that nature on the back of the intake and I have the two on either side removed but can't get to the middle clip very easily. There is some kind of plastic mount and some other plastic running down the back. Hard to work back there and I have big hands. Are there ant tips for doing this? SO far everything is off with the exception of the back middle clip and whatever it's attached to.
You just want to remove this?
On the 6.2 Silverado, there is a cover (not like the one pictured) that goes over the actual intake. Looks like runners on top of the real runners held down by 4 bolts on the sides and stuff I can't see on the back, and stuff on the rear is mounted to it, very little clearance, I just want to know what I'm working with that is making it difficult to remove, and all the harness connections on the side are removed and out of the way.
I don't know what I'm feeling back there and can't visualize it. got one tab still keeping it together I think and it's a bear to get it separated.
I have a 5.3 and a 6.2 and i have no idea what youre talking about. Because what i posted is the "engine cover"   also the 5.3 and 6.2 are pretty much identical "looking"
This may help. It is meant to hold the wire harness as well as keep IAT cooler.
Move to 8:22 IT SHOWs the clips and how too.
Oh that would be the intake manifold.  Ihavent had the need to pull mine off yet.  Sorry
That cover is part of the intake manifold.  It stays on the manifold.
Why are you trying to take it off?
I'm getting ready to do this to my truck.  From what I've found on the internet,  There are three plastic clips holding on to the back of the cover.  I heard is was a real bitch to get off.  Hopefully my 1.5" body lift will come into play and give me a-little more clearance to get my hands back there.  I'll see if I can find the other pictures I found of it.
Was going to check the runner gaskets for overall condition (on the older moels as they age would form air leaks after about 3~4 years). Getting ready to inspect the intake valves for carbon buildup and determine it they need cleaning since it's direct injection. Plus I don't like covers and tend to leave them off unless they have a specific purpose.
Huge help... Thanks
Just removed mine last night.  What worked for me it to remove all the bolts with the intake still attached to those three tabs.  Then i lifted the intake up and pushed it over to the drivers side as far as I could.  Then I laid a big moving blanket on the passenger side of the engine and crawled on top.  That allowed me to easily reach all three tabs with a screw drive and pry them out.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
