Usb charging- Android
I have a Motorola Moto Z that's about 2-3 years old. When I plug it into either of the usb ports under the far left cover under the radio/climate area, the phone screen intermittently shows the lightning bolt over the battery indicating it's charging. It cycles on and off despite trying several cables. Are those ports just underpowered for charging?
If you’ve tried different cables it sounds like it’s something in the vehicle. A loose connection on the back of the USB connector? Is there one in the center console you can try?
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
