Silverado vs Tundra
6 hours ago, aaronk said:
My last 4 trucks have been Toyota's with the current one being a Tundra.  Looking at jumping ship with my next truck as the 2019 Tundra is literally lipstick on my 2012 Tundra... I'll say the Silverado rode much better then the Tundra; however the 8 speed transmission on the truck I drove was horrible in comparison.  The Tundra engines really only have two common issues - air injection pump failures and cam tower leaks.  I've gone 150,000 miles on mine and have only had an issue with one air injection pump and valve.  Total cost of ownership has been ridiculously cheap over that period of time.  One set of brakes, one serpentine belt, one spark plug change, and beyond that just oil changes.  Trucks burns absolutely 0 oil even at 10,000 mile oil change intervals.  Resale value... I was offered $15,000 in trade as a starting price for a 7 year old truck with 150,000 miles.... I'd call that pretty good!
The 8 speed transmission in the 1500 scares me though, otherwise I'd have one in the driveway right now.  Thinking maybe going 2500HD instead so I can get a normal V8 with no AFM/DFM and a solid transmission.  A Tundra in comparison to a 1500 really isn't that much different in price where I'm at.  My base Tundra has some features a 1500 doesn't and the 1500 has some features my Tundra doesn't.  The ancient infotainment system offered in the Tundra absolutely kills me though...
The 6.0 in the 2500 is a pretty solid performer, no lie. But the 5.3 is as stable an engine as any. Previous gen trucks had an issue with the AFM but they seem to be sorted at this point. To be fair I tuned mine out, so you can always tune or replace with non AFM parts if you're that concerned. I can't speak to the 8speed, seems like there was a handful of issues with hard shifts and looking for gears. My guess would be they have mostly solved this by now since it seems like a tuning thing. YMMV though.
If I could do it all over again I'd prob go 2500 so I got the longer bed and beefier axels but that's mainly around my desire to run 37s+, not for any practical application.
To be honest with you, if the Toyota was either on par from an interior perspective, boxed frame, etc. or cheaper, I would probably have gone with that. Just a hard pill to swallow with getting neither.
  • Replies 46
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
