Add-a-leaf, already have a block?
Hoping for some advice here. I have a 2014 Silverado 1500 High Country crew cab standard bed 6.2L 4x4. It has a small spacer lift kit installed by the dealer I bought it from. I'm planning on replacing everything with the BDS 4.5" kit next summer when it's time to get new tires, but in the meantime I need some help in the rear. It has factory leaf springs with a 2.5" block, and years of hauling stuff in the bed has made the leafs sag a bit and the rear sits level with the front. I have a small 20' travel trailer that I pull, and I don't like the back dropping so much when I tow stuff or put sand bags in.
My question is, can I put an add-a-leaf in the rear leaf pack and keep the block in there to give it an inch or two of additional lift? Or is that going to cause issues? It would be a temporary fix until I replace the leaf springs next year.
Thanks!
Adding an extra leaf can be done with no issues. Keep in mind your ride is going to definitely get stiffer. I would go with some air bags but I am not so sure that is an option for you if you plan on lifting the truck in the future. I have had air bags and they are awesome, The ride is nice and you can adjust the height to where you want it.
Go to a shop that specializes in leaf springs.  They can repair, add to, rebuild or replace your current springs.  In the long term, I bet you'll find this to be the best and most cost effective  solution.  Band-aid remedies can be disappointing!  (They will also setup the springs to your desired strength and stance.)
??This.  Add a full size, full length leaf at a minimum, instead of an Add-A-Leaf. An add a leaf is not a good addition for your springs in the long run. It will create two new flex points on your springs where the shorter, thicker Add-A-Leaf ends. These new flex points will potentially cause the existing leaves to fail by concentrating too much weight on a section of the spring that was not designed to support it. That’s also why, in worst case situations, the existing leaf cracks at the end of the Add-A-Leaf, causing a catastrophic failure.
Go to a real truck spring shop, you may be pleasantly surprised at how affordable their options for upgrades can be.
    • If one can't be found, a good automotive upholstery shop should be able to replace/sew in a new panel where the damage is on the old cover. It might not be the cheapest option..
    • Does your dealer charge you for the tire rotation on top of the oil change price ?. I haven't had any service work done at my dealer yet other than when I brought it back soon after owning it to have the front end aligned to correct the steering wheel being off center a bit. Oh they called me at least twice hounding me to bring it in for an oil change and pushing a 300.00 package of oil change and tire rotation and whatever other quick simplistic checks they would do. Only going off of what a friend gets charged for his half ton for the basic oil change and its the same amount of oil as the L8T holds, it was about 150.00. Once one buys a set of tires from most shops these days or so I believe, they will do free tire rotations and some do free tire balancing as well as free tire repairs.    Certainly doing a tire rotation is no five minute job, and definitely not at home but because I run a set of winter tires on their own wheels, I swap them at home and its a one tire at a time deal because of the tire season swap although I jack up the rear and do it and drop it back down and then raise the front and do them and coordinate the tire rotation into that process for both sets of tires. I am using a floor jack though and if I need to raise both ends at once I use a couple sets of jack stands to have all four tires off the ground. I use either an air impact or battery impact and have electric impact as well so no shortage there of easy methods to spin the lug nuts, and then retorquing the lug nuts. None of it goes quick though but my wages are cheap though ... zero. I live an hour out of town, its easier just to do things like that myself than waste a bunch of time in town and having to make an appointment and probably a special trip and sit there at the tire shop waiting for them to get my vehicle in and get it done and not screw something up in the process.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
