1 hour ago, str8dum said:
Red_5, have you measured the rake with the fronts at the 4 notch?  3rd notch leaves 1" rake.  Is 4th dead even?
I just measured and got 37.5" front and 40.25" rear from the ground to bottom of black fender trim. I have my 6112s on highest setting and I swapped the rear block to one that added about 3/4" lift. I have an NHT so maybe I have stiffer rear springs that create more rear height? I definitely still have visible rake which I wanted because I tow a trailer.
Anyone try these 6122's on a 6" lift ? Wondering if these are a better option over the 5100 for a lifted truck running the larger tires. I would just keep the lift kit upper 6" spacer and put these in like the stock ones.
I would also like to order them assembled so I dont need to compress the spring. Anyone know of someone that sells them assembled ready to bolt on?
Edited by gapple12
I was going to do 3rd setting on mine but ended up getting 4 wheel parts to do the top setting. Was thinking about a 2" block in the rear. I have the 5100's in the rear I installed myself. With the 6112's in the front I still have a slight rake, glad I went on the highest setting and don't even think I need the rear block either.
I now have over a 1,000 miles on the 6112/5160 setup and am very pleased. I think they need a bit of break-in so they've been getting better with every mile, they handle all bumps better than stock. My friend who has a stock Raptor was impressed with the ride over bumps - we were only on the highway. I also just towed my ~8,000 pound loaded toy hauler to Laguna Seca for the weekend with another friend and we were both impressed by how well the truck towed and how well the suspension handled things. I like the truck so much more now, drives better in every situation. GM suspension engineers should be shooting for something similar stock. I'd rather have a good suspension out of the box than a multifold tailgate for instance.
I have a couple thousand miles on this setup too, still very impressed at how they absorb big bumps and yet control the truck so smoothly.  I think the spring rate is similar to stock but these massive bodied shocks just absorb all types of abuse.   Amazing how cheap they are compared to many of the other 2.5 coilover setups I have purchased in the past.
I'm going to be ordering the 6112s (3rd notch) for the front and 5160s for the rear. What size tires are you guys running with 17" wheels? Where can I order these from that they are assembled
I ordered my 6112s built from Battleborn but something happened when they were being assembled and, well, they didn't arrive assembled. They refunded me for shock hats because at the time I was in a hurry.
I currently have basically stock sized K02s on OEM 18" wheels. I have about 44k miles on the current set of  tires, I'll go a little bigger with the next set which is probably still a year away.
Im planning on ordering them assembled at 3 rd notch and putting new tires on after install. I emailed battle born and they told me 285/70R17 will fit. Guess thats what im going to be going with
2" is small for a 5500 lb vehicle. 2.5" with large shafts to me is adequate, but you could easily do 3" and not be over dampened.  Depend on a lot of other factors of course. I really wish they did not take so long to release, would have saved me some money. Instead went all out on good 2.5's. Do make a big difference but not cheap.
Glad you all like what you got, Bilstein is hard to beat for value.
2 hours ago, Carrieron said:
Are they set up at the 4th notch and that’s why you went with lift blocks? What size/brand tires are you running?
Yes, they're on the highest setting and yes, I still wanted some rake for towing but I don't think it's necessary. I think I would have had enough rake without the higher block on my Max Tow but we did the work all at once.
Tires are BFG KO2s in 275 65 18 E load. I "downgraded" to OEM 18s from the 20s that came on the truck because I wanted more tire. I'll likely go a little bigger when these tires are down in the next year or so.
  • 5 months later...
I just got my 6112s installed on my 2016 Silverado 1500 and holy ****** the bounce is insane. Highest setting but that should not cause bounce like this. Anyone have any suggestions? Based on the bilstein reputation, theres no way this is normal.
  • 3 months later...
I just install 6112’s on my 17’ Sierra with 5100 on back.  I did not have the luck you guys have had. I got 1.75” of front lift on the top setting.  Now the bad news. I have a terrible ride now. High Speed compression is great. Pot holes dont hurt anymore and can take speed bumps fast. But low speed Compression sucks. Going through dips in town or a Bridge approach will about bounce/buck you out of your seat. Almost as if the dampening doesnt exist.  Best way I can describe them is VERY springy and almost as if there is no shock just spring.  Anyone seen or heard pf this?
    250.3k
    BDS my HD
    BDS my HD
  • Who's Online   0 Members, 0 Anonymous, 649 Guests (See full list)
    • Hello hello looking forward to expanding my knowledge of the 2026 2500 HD that I just bought.   Truck has 3500 miles on it four-wheel-drive crew cab and I’m about to put a 6 1/2 inch BDS lift on it 18 x 10 -25 offset with 37’s   Already have the wheels and tires just waiting on the lift install in about three weeks   Question what surprises am I not gonna be happy with?  I’m not new to lifted trucks so I know that acceleration towing gas mileage all that is affected..   Question is those of you that have this truck this powertrain with a 10 speed Allison and have done the mods that I’m doing,,, how bad is it? Is that Allison constantly gonna be hunting for the right gear to go into? And what about towing, acceleration, fuel consumption as mentioned?    Lastly how come I can’t find any ring pinion gear set up for these axles and when could I expect to see them?   I apologize if there’s any typos I’m doing speech to text on my iPhone.
    • I've got a 2013 2500 6.0L Flexfuel. Drove the truck earlier today with no issues. Went to run an errand tonight and noticed key fob wouldn't work. Figured battery was dead, so replaced fob batter. Still wasn't working. Grabbed my other set of keys with the other fob and that one wasn't working either. So I manually unlock truck and insert key. Interior lights come on, dashboard lights up, turn key and truck starts. Turn truck off, like a moron, and try starting again. This time no crank, no click, no nothing. Lights still come on and dash lights up, but now I'm getting a service 4wheel drive, service tire monitor, etc. Check voltage on battery and Im showing 12.2v. Throw my battery charger on it and give it 15 mins and try starting again. But still no crank no start. Decide maybe its a bad battery, run to autozone grab a new one and put it in. Same issue. Disconnect battery and let it sit for 15 mins. Try again and still nothing. I had managed to roll the windows down earlier as its a humid night, but now I can't get them to roll up. Power locks are also not working now. Then randomly I try the key again, and it fires right up. Immediately I roll up the windows as we have nothing but rain forecast this week. I shut it back off wait 30 seconds and start up again. Worked a 2nd time. So turn it off, start putting things back together. Try one more time, and back to no crank no start. And now the car alarm starts going off. Had to disconnect battery and leave it that way for the night as I don't think my neighbors would appreciate my alarm going off again tonight. Any thoughts or help would be appreciated.
    • No one will care for you like you care for you. Do what you can for as long as you can. IMHO of course.
    • How about them NICKS!!!
    • Hi there.  Long time lurker, first post.    i have read the previous posts regarding the water ingress problem with this emblem.  I bought my 1500 SLT the  summer of 2025 new and after reading the MANY problems with these emblems failing I decided to install one anyways.  As per a YouTube video, I sealed ( or tried to) this sign with silicone sealant around the outer perimeter joint and the holes that were already somewhat sealed on the rear plate of the emblem.  And installed the connector assembly using dielectric grease on the connectors. The installation looked great and worked well for about 4 months……then FAILURE.  Grrrrrr…… I live in the great white north and wash my truck weekly in an automatic car wash  to keep the salt off.  Let me tell you that removing the old, failed emblem is a whole different animal than removing the OEM individual letters without removing the grill assembly. Mainly because the illuminated logo is built differently than the original letters which  you can remove the red surface lettering with a knife or some kind of blade which gives access to the tabs which hold the logo onto the grill. So I had to essentially destroyed the old emblem to remove it. Doing so killed my chance of doing somekind of autopsy on the failed , old logo.  But there was plenty of water inside when I ripped it apart.  Prior to installing the new assembly I tried it with the old harness and it works fine.   Does anyone have any insight as to where the water is getting into this emblem? I intend to seal the new logo with slow curing epoxy this time around using a syringe.  I think this newer emblem may be an updated unit which I hope GM got the vendor to fix. It has an October 2025 date on it.    If this one  fails,  I am just going to revert back to the non-illuminated letters….AFTER PULLING THE GRILL.    Any thoughts on sealing with epoxy would be appreciated. Thx!   Doug
