Upper Control Arm - Help me choose
pwgsx
I currently have a 2017 LTZ with a 2 inch block under the bottom of the strut.  The ride sucks and im rubbing the stock arm at full lock with 275/60/20 tires and unknown offset XD wheels ( ill find what they are in a day or 2 ).  I finally decided on the Halo Boss Coil overs as they seem to have less issues than the Fox ones.  However I keep reading that its best to get some better UCA's to help with the angles, travel and rubbing.  Im already blowing my wad on the coil overs and only want to do this once.  What is the best UCA's that I should get that wont break the bank?
I just installed a set of Cognito Ball Joint arms a couple weeks ago. I also have Boss Coilovers and initially set them up with two spacers to get the 3" of lift with Rough Country contro arms. With the stock wheels I had to run 1" BORA spacers to keep the wheels from rubbing.
The spacers caused vibration and when I took them off, the wheels hit the edge of the rim on an angle of the arms.
I later took out the two spacers under the coilovers and installed the Cognito arms.
Happy to report the ride is better and if there's any rubbing at all its minor and only at full lock.
So far I haven't seen any evidence of rubbing on the control arms.
Sent from my SM-G975U1 using Tapatalk
Did you go with the Cognito ones listed above or the more expensive option?  How hard was the install and did you have to cut out the bump stops?
Yes those are the same part number.  They were easy to install.  I previously cut the stops out when I installed the Rough Country arms.  With the Boss Coilovers installed, I did not have to remove them.
If you plan to do both at the same time, I would advise getting a paint marker to mark your current alignment positions so that when it goes back together your alignment should be close enough to drive to the shop to get it aligned.
Good tip, I saw it in another video too.  Do you have any squeaks from the cognito ball joint?  A Google search popped up a handful of people that has squeaking.  Did you not like the RC Arms or was that part of the rubbing issue you had?
No squeaks that I know of.  For my application, the RC Arms were fine except the rubbing without a wheel spacer.  I also think that because I dropped an inch by removing the spacers under the coilovers, it changed the geometry and put the wheel further out towards the fender allowing more room for it to turn.  The Cognito arms are not as wide as the RC, and there's an angle on the RC arms made contact with the wheel.
As far as build quality the Cognito have better bushings and I think the ball joint is better as well.
Ill be ordering both up very soon. Thanks for the info!  By the way, did you do any kind of limiting straps since the bump stops were cut out?  I dont offroad so I wouldnt see this as a big issue for me.
    • The “engine hours” display is there because the truck detects the key presence as you were thinking.   My first step would be to call a dealer service person and ask if this a known issue and how they deal with it. If you don’t get meaningful advice there, i would try a couple of DIY things before bringing it in for troubleshooting/repair.   It sounds like a mechanical key detection switch is stuck, but I have not actually seen what the internals look like. Maybe spray some Caig Deoxit (electrical contact cleaner) in the key hole and work the key in and out in case it’s an electrical contact cleanliness issue.  If that doesn’t work, next apply whatever lubricant GM recommends and work the key in and out a few times.    Good luck with it.
    • Carbon on valves would be the least of my worries on a light duty, 1500-series pickup with 357k provided the engine still ran halfway decently. Everything else is likely toast, on its way out, or has already been mauled to death by cheap mechanics and backyard fixes. Those kinds of trucks nickel and dime a guy to death.   I wouldn't think having the top end cleaned once or twice would be a big deal on a 5.3 but maybe it is?
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
