Summit15101 Posted June 21, 2019 Posted June 21, 2019 Hello so I have a 1997 GMC Sierra 1500 with the 5.7 engine in it. It has about 350000KM on it. When it sits for more then a couple days it has a really hard tim starting. I am thinking it is related to a fuel pressure issue? I can spray some fuel right down the intake tube and it fires right up perfectly. It also idles and run normal when it is running. So if it was the fuel pump wouldn’t it run rough once running? Any help would be appreciated! Sent from my iPhone using Tapatalk
wreckdiver230 Posted June 21, 2019 Posted June 21, 2019 you either have the check valve in your fuel pump bleeding off , or an injector leaking, many videos on youtube address this problem
BlancoSilverado Posted June 21, 2019 Posted June 21, 2019 Also the fuel pressure regulator at that mileage and the new ethanol gas might be bad. If there is an Orielly/kragen auto parts you can rent a fuel rail pressure gauge to see what the pressure is/bleed might be located(what system).
riverbanks Posted June 21, 2019 Posted June 21, 2019 Do the old,cycle key a couple of times before cranking,gives you a idea if it's bleeding down or get a gauge and watch it
