Can anybody help me with a legit check?
  • Replies 45
I just looked at my real genuine GM wheels and they have the size stamped in it as well as INDIA
34 minutes ago, newdude said:
Got any more pictures of the back or the face of the wheel?
Are some rims made in "india" and others in "china" my denalis say "china"
8 minutes ago, 1SLOW1500 said:
I say just offer $1000 cash and don't care either way.
Haha tried that already hes stuck at 12. Talked him down from 14
Go see them have 20s all wrapped together and pull it out say it is all you can do. Hustle it. They appear real but I would have thought the pic would have been the part number
Hes a tough 1 and hes firm at 12. Dont like to carry 20s especially 1k worth. That is bulky as heck. Trust me I'm basically the haggler king Haha but sometimes I meet strong negotiators that wont budge
If they are real , and I think they are , $1200 is a good price. Not a killer deal but not bad either.
I think these wheels are the best looking factory wheels especially the 22's.
I'd buy them for that price all day long. You see what they cost new right? Those look like new too.
I love them on my truck.
I'd buy them for that price all day long. You see what they cost new right? These look like new too.
Damn that's beautiful. I need them on mine now
1 hour ago, dieselfan1 said:
The markings on your wheels look cleaner than the 1s the guy sent me. Does yours have rye product number on them?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
