2005 GMC Sierra 1500
New fuel pump installed by a local shop. Fuel gauge worked when i brought it there now it is not and they cant figure out why. R and r fuel pump not sure where it came from. Gauge only moves when you cut off the key other than that stuck on 3/4. Anyone else have that problem and how do I fix it?
Sent from my Pixel 3 XL using Tapatalk
Compromised connection at sending unit,many times a old pump while failing,maxes the circuit,weak link is the connection
There is a tsb on the plug redesign done by gm.
Also, most after market fuel pumps come with a new pigtail as the wires on the old ones often chafe.
The only one i could find that matched what the shop charged me was a delphi pump. Is there any known problems with these pumps?
I'm going to bet that the pump harness has been changed already in the past, and the splices are failing. Even with the proper heat-shrink butt connectors, I've had them fail and had to fix them. I wonder if they bothered to replace the connector (typically supplied with all the new pumps), or if they left it and now after disturbing it, it is making a erratic connection on the fuel level circuit.
Im not for sure but they said they put a new plug on yesterday. I would have to look at the splices to see if they might have come loose. I hit a bump in my yard and the gauge went from stuck on 3/4 to stuck on empty.
When did you hit the bump, before or after plug replacement? If after,you can do a wire wiggle test,while someone is watching gauge,any where you can along frame,stuff happens,read thru this site,it's seen it all
Yep on wires,now short story,I picked up a new mower battery at advanced this spring,on sale,in flyer,got there,clerk said, delivery was moments ago,totes not gone thru yet,I asked,could you get the battery from one,he got pissy,so for the next 5 minutes,I heard totes flying, banging in back room,what's the odds that they had ruined product?
This was I believe an auto zone pump not by choice. It is a delphi which i heard is the stock pump but there's always been bad parts. Is there a way to test the float sensor if i were to pull out the pump?
I use Delphi, good pump,if you're taking it out, just warranty it, maybe the wiper is barely making contact
    • I'm suborn like that Ed. There's a plaque in my doctor office that says, "Don't quit, take a break." Works for allot of things.    Reality is, the wife loves her SUV and even given it's issues, she'd buy another if she found one with low enough miles. Then again she has me to maintain it.    Most of what ails this thing is GM shooting themselves in the foot and by extension the buyer. Besides a ridiculous breather system the cat warm up strategy, IMHO, is the dumbest thing I've ever seen an OEM do to a vehicle they warranty. On cold start it r-e-t-a-r-d-s the ignition to like -17* ATDC and dump fuel like kicking over a pail to force combustion in the CAT's for rapid warm up. This literally hoses the oil off cylinder walls and creates enough varnish precursors to stick rings in even well maintained engines. THEN if that wasn't bad enough they recommend using a wanting fluid specification at equally stupid interval.    Common to all GDI motors I'm aware of is this silly practice of driving the HPFP off the cam giving a leaking pump direct and unchecked access to the crankcase. And sir, eventually the ALL leak. Your job is to "catch it if you can". Yes, these are the same people that removed dipsticks from engines and transmissions in belief Joe Average wasn't capable of checking, reading and maintain his own vehicles fluids. Sadly  and in large they were correct. Most people these days can't tell a sparkplug from a fire plug.  Great ideas one and all.    Every move and every error calculated to defend themselves from the law and their own customers.
    • Most online suppliers and Amazon. All have noted "not for use with Bose speakers".
    • Very interesting thread. Definitely didn’t expect to see this kind of mileage out of that engine.
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
