I turned too sharp with my fifth wheel and the plug end pulled out of the cable. has anyone had this issue? I'm being told it cannot be repaired???
On 12/17/2019 at 10:22 AM, Christopher Murphy said:
Can you take a picture of the Amphenol part number. I have Amphenol looking for the connector but can’t seem to find it in their system. Thanks!
I did the same exact thing. Did you ever get a new connector?  I need one.  Did you connect it to RG-58 cable?
On 8/15/2020 at 2:58 PM, hptulsa said:
Need some pro help!  still trying to find a cable to replace the OEM "Trailer" camera cable that i tore up.  I found this website to create your own cable... can anyone put it together for me based on the pics, etc on this thread!  I'll pay you!  https://www.pasternack.com/t-cable-creator.aspx
  Hide contents
Did you find a fix. I could really use a fix to replace connector.
On 8/19/2019 at 10:20 PM, sdelam said:
What is this connection called? All I can find online for trailer cameras are RCA and 4 Pin. I am trying to see if I can find an alternative camera set up. Thank you in advance.
Would something like this work? I would also love to get an alternative camera setup working solely because the price of their camera is crazy high.
https://www.elecbee.com/en/fakra-cable-assemblies/13929-fakra-cable-straight-fakra-z-type-female-to-gx12-4-pin-male-cable-assembly.html
Not sure that would work.
@Rjsires and @TIMAYZ posted earlier that the connector into the bumper appears to be a PAL DVB connector.  See comment at
Of course, the adapter/connector above wouldn’t be waterproof.  I have also seen posts that it's a FAKRA connector. I haven't tried either to see which one it really is.
I’ve tried to look for just the OEM black waterproof connector without any luck. Was also hoping to build my own camera and cable kit.
Edited by ShogunKC
Removed unneeded quoted posts
Has anyone tried to remove the silver coax connector from the black plastic plug/connector that goes into the truck?
I've tried twisting and it doesn't seem to want to come loose. I'm wondering if maybe it needs to be pushed in at the same time as turning to disconnect the two. IMG_2247.thumb.jpg.51bcd9f9efdadb7f0100c537831773b4.jpg
14 hours ago, Freakyjerk said:
I cant seem to get mine off as well. I was able to remove the small C clip but it won't separate the two connectors.
I got a replacement metal connector for the coax and asked them how to remove it from the black connector - they said to use heat. I tried a lighter and it wasn't enough. Haven't gotten out the torch yet. May need a trip to Harbor Freight to get a heat gun. They said that it's held together with locktite.
On 12/16/2019 at 4:35 PM, hptulsa said:
connector Amphenol 31-14693 is stamped on connector.,..
HPTulsa, I made the exact same mistake.  Will you please share how you got this fixed?
On 5/28/2021 at 1:15 PM, Freakyjerk said:
I was able to get mine apart with a grinder.
I recommend the grinder method. Applying heat did not loosen the connector in any way. But, it did manage to melt the plastic inside the black connector and the pin is not centered and is sticking out of the connector when it was flush.
Once I had the coax connector off, I could remove the c-pin and remove the metal connector from the outer black plastic holder. There are no part numbers or anything to identify this piece.
Going to try heat again and seeing if I could push that pin back into place...
I was able to get the pin in the connector reset back to the correct position. Just applied a little heat and used a wire to push it back and held it there while the connector cooled off.
    daveishi
    daveishi
  • Who's Online   1 Member, 0 Anonymous, 855 Guests (See full list)
    • Because that is IDIOTIC, much like this question. They've already been forced to do it by past administrations - why would you roll that back when it's a GOOD thing?  WHO IS ARGUING FOR LOWER MILEAGE???? 😂  NOBODY IS!!   I'm certainly not! What I want is RELIABLE vehicles again that are worth the price paid!    I don't get your logic here ...   In 2003 I paid $2,200 for our '86 Grand Marquis. It's STILL running and I've never been inside the engine, aside for the timing cover since it was leaking, so I threw a new timing set in since that makes sense. Transmission is ORIGINAL. Electric pump in the gas tank is ORIGINAL. Rear end is ORIGINAL. I'd have to hit my head REAL hard to want to pay $60k or more for a car that still can't come close to the comfort, seating and storage space, or reliability of this one. Nothing is even in the ball park! Hundreds of thousands of brands and models have been built and sent to the crusher while this one keeps on going!   https://postimg.cc/Z9XRrCSg   I've got a whole fleet of cars, motorcycles, and a truck close to this age for summer and winter. No one could pay me enough to buy anything built this century. I have zero use for any it.
    • Since I'm the one who has to fix them when they break, I'll take vehicles over 30 years old all day, EVERY day, over ANY modern crap. Have you attempted any repairs on anything built after 2006? It's a friggin nightmare, and gets worse the newer the model year.    If I had the will or desire, I can make any car of any age outside of a Model T (I don't have THAT much will ...) just as powerful, comfortable, and have all the tech the new stuff does, and get pretty close in mileage, too. I prefer SIMPLICITY. The less the vehicle has, the less to fix WHEN it breaks, not IF.   I'm glad you snot-nosed punks don't like them. More for us, plus that keeps the prices from climbing more than they already have.👍
    • Bringing this thread back on topic. I just noticed the incredible lack of bright chrome across the entire new lineup. Even the Denali has tinted the brightwork in the grille and has none elsewhere. None of them have chrome bumpers. As far as I can tell there aren't even chrome mirror caps. I'm curious if this also happens out back? Are there no chrome rear bumpers either? This is quite the departure for GMC.
