6.0 Exhaust Manifold Bolts
For all those wondering...
The GM exhaust manifold issue is alive and well with the 2014-19 generation.
I just had all driver-side bolts replaced under powertrain warranty. I have 44k miles on the truck, and heard what I suspected was a manifold leak.
Boom - warranty replaced it. Let's hope the passenger side bolt breaks before August of 2020!!
See my thread i posted a few weeks ago..my 2015 had it... only one bolt luckily at 38k
Sent from my SM-N950U using Tapatalk
Just change all of them one at time preventatively... warranty doesn't last forever lol.  They are really easy to change when the heads aren't broken off yet lol.  I have thought of doing the ARP studs with the manifolds but I am sure those will still shear off with the movement of the cast and then be impossible to get out being stainless.
Same problem with my Detroit 12.7L in my semi truck.  I just ovaled out the bolt holes in the exhaust manifold  and it cured the problem.  When you have two different metals connected, the expansion and contraction rates are different and eventually something has to give.  Cast iron manifolds and aluminum heads are going to fight against each other in this regard.
So one can either oval out the bolt holes, or do an alternative solution.  Something like brackets from Kral.
https://kralautoparts.com/parts
I didn't see it either. Oh well. Yes - mine was only one. Of course, passenger side is a little more difficult to get to.
offroadman83, I looked for your previous thread and can't find it. Is it titled as something other than manifold bolts?
Its in troubleshooting
Titled something else "well i had to take it in" or something like that. Not really much tech just crap
My 2015 has broken exhaust manifold heads on both sides.. Sigh.. I am at 130k miles though.
Is everyone replacing the manifolds when they change out the studs as well?
    • Folks, Have a great new 2026 WT  (std cab, 2.7/4WD) w/base 40/20/40 mech adj bench "fake buckets"  (with lower and upper center console) heavy vinyl seats.  Overall the seats are very comfortable and the vinyl is heavy and appears less likely to 'split out'. Am very tall (6'5")  + a bad back/osteporosis/former hyperparathyroidism so ease/range of movement is a bit restricted.  The truck rides a bit high and I use a nerf step bar w/my left foot to step in, then I put right foot/leg in, drag my butt in  & get seated.  Worked fine in my 2018 RAM quadCab. But I end up dragging my butt over the left raised sidecushsion area of vinyl seat, and due to texture there's fair amount of traction on slide inward.  (ArmorAll didn't improve.) If the seat were even ~1/2" - 3/4" lower it'd be helpful, but base seats just have the forward/backward underseat bail and the side lever for tilt which really doesn't affect seat height.   I really don't want to 'de-puff' the left side sidecushion forming the  fake 'bucket'. I know one company sells 'seat elevator blocks':  but is there a simple way of lowering the height of the driver seat instead?   Thanks Bill W San Jose
    • I have a basic 2026 1500 WT  (2.7L/4WD reg cab shorttbed). Comfy, generally happy with electronics/radio - but is there a way I can add switches to steering wheel right-side position (curr. empty) so I can adjust volume, push phone button to voice dial, etc? Bill W San Jose
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
