Stalling 5.3 LM7
2005 Silverado 1500 5.3 LM7
Backstory: driving when all of a sudden engine shuts off and won’t restart. Towed home and was able to restart for a few seconds then stalls. No codes, no indications. Like flick of a switch
What I’ve done so far:
Fuel pump is good. Puts out continuous pressure of 55/60 psi
Cleaned PCM main ground under drivers door
Have strong spark
1/2 tank of fuel
No codes
Swapped mass air flow with known good one
Dielectric greased PCM electrical connector
Small single wire for engine ground is not loose nor cut in the back of engine bay
Was able to have run for 10 minutes without any problems then it cut out
Checked anti theft trough scan tool and everything is agreeing with each other
Any advice? Thanks greatly appreciated
Many possibilities,crank sensor?wiring harness? right behind power steering pump is a harness rub issue,get it running,and start wiggling wires,see if you can make it stall
Is it really a half tank of fuel or is the gauge showing a half tank? Did you verify it had fuel?
    hotfish
    hotfish
  • Who's Online   6 Members, 0 Anonymous, 659 Guests (See full list)
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
