Good question, I am planning on installing a SiriusXM stratus 7 receiver and was wondering the same thing.
I found a place to tap into auxiliary 12VDC. Under the drivers side dash there is an extra connector X260. It has a blank mating connector pugged into it. I will be going to GM to see if I can get the pins.
In the GM up-fitters website you can download the breakout but the Black wire on 1 is ground and the Violet/Yellow wire on 6 is the accessory power. It is a 14 pin plug.
x260.doc
x260.doc
Thanks for the info. Going to use this tomorrow to hook up some additional USB Charging Ports.
Keep me posted on this. I would like to set up an additional USB charging port and keep it clean like a factory install. If you can post a write up or PM how you did it I would really appreciate it.
Did GM sell you the connector pins? If not where did you find them? Thanks
I have them on order from GMpartsdirect.com
Have not received them yet. Today I will swap the 50 amp fuse (F27/F28) in the passenger side fuse box so the accessory power will be tied to the retained accessory power and will try tapping into the extra pin near the F28.
Part number is listed in the attached word document. Two different pin sizes. Also swapping the fuse did not change the extra pin to RAP. So I wired the sirius power cord to the cigar lighter wires
Edited by RobZ
added content
If I am reading the word file right the terminals are 13575818 and 13575824? Just confirming because gmpartsdirect.com lists those numbers as "wire" and a little over $6 each.
Yes, they are the pin crimped to a 6" piece of wire with a butt connector, not cheap
  • 2 years later...
Does anyone know what fuse the violet/yellow wire is on?? I found the x260 connector yesterday, but pin 6 is not hot when the truck is running. I'm thinking it's a blown fuse.
    • I am having similar issues.. 08, 4.8L granted I did had a fender bender and minor damage up front passenger side but I don’t think it had anything to do with it.. I had the high and low pressure checked and my fan for my radiator keeps coming on.. replaced the pressure switch and don’t want to keep throwing parts at it. I did have some minor problems here and there like on long road trips sometimes the ac would get a little warm and then on the highway as soon as I give it a little gas or get a little heavier on the petal it started running cooler. Never had an issue with the ac besides the here and there.. but I also started having issues when I fuel up now it takes a bit to start ( super embarrassing) it runs fine and once started ( only happens after fueling up) starts fine any other time. Could they be related?
    • Spent a small fortune on fuel this weekend.   $6.69 diesel, 18 gallons of that. $6.99 92-octane ethanol free, 10 gallons of that for yard machines $5.59 87-octane for one of the cars, 11 gallons.   $250+ and I didn't even get a tug.   Hormuz ain't Hormuzin again, did not see that coming...LOL
    • Appreciate the advice. I've watched multiple videos. Most showing the most complex for those that have a center console, to one that showed maybe 2 pieces of trim being removed, like 6 screws, pulling back the screen and switch assembly, and installing the inline module. And this was a new/newer Silverado. That didn't look too bad. All the others show alot of trim pieces that need to be removed. I've broken those kind of tabs/clips on my C8 Corvette trying to get to the battery, and that was a lot less clips than what I think is involved here after watching multiple videos and looking at my dash today. I have one on the way. Called a reputable stereo place about installing it and got a "minimum" price of $175. Ouch! Looking forward to seeing what the instructions have to say.
    • Hard to say what the issue might be. Anything from the ability to cool the AC condenser up front, to blend door issues in the HVAC unit, to refrigerant charge, to compressor issues or issues in the lines.   Report back what the techs find on the 29th.   GM has service publications which list acceptable vent temperatures and AC pressures at given ambient temps and humidity. They probably won't touch the system if it's operating within those ranges.   I'm also surprised to hear your 2024 with the L8T is still using R134a? I was pretty sure the HD's had switched to the new refrigerant around 2020.
