I get a wind noise on the drivers door. Seems like it is around the windshield post and where the door meets. It almost seems like it turns into something rattling.It does not do it all the time.yesterday I drove 60 miles and no noise. Today it's making the noise. I checked the mirror and door seals and been trying to figure it out for a week.this one has me puzzled. Maybe it is inside the door.Today I made an appointment to take it in.not very confident with shop as yesterday they said they could not hear my axle jingling away as we drove down the road.
I have a 2019 Silverado LTZ with the same problem. Fortunately the service techs heard it too. However, without an existing bulletin on the specific problem, they are going to have to take the door panel off. It's like having a family member undergoing major surgery.  I'll post the resolution if they find it.
Thank you. I drove 180 miles the other day and it did not make the Noise at all.it was not very windy out however and I'm not confident that it has just gone away and won't be back. I do believe it has to be inside the door. Thanks for keeping me posted.
Any updates to the noise
My noise ended up being the plastic duct work behind the drivers side instrument panel going to the vent on the dash.when you were at a higher speed it would rattle on top of the metal bar that is part of the dash assembly. I placed burly seal between the duct and bar. I found the problem on this forum so it has been a issue with other trucks.
Thanks for the update. Was it a rattle noise or a loud howling? I have an AT4 6.2 with 1500 miles on it and for the first time over the weekend heard this very loud howling noise that came and went when I was driving about 75 mph in strong crosswind.  So loud my wife and I went WTF.
I have a 2020 Silverado with the same noise problem when driving 70/75 mph and a high crosswind. Seems to be coming around the side mirrors. If i pull the side  mirrors in, the howling stops. Side mirrors out, howling starts. Noise is not constant, but very irritating.
1 hour ago, carortruck said:
Any update on this???
2020 crew cab same noise...sounds like someone playing the recorder badly.
Crosswind highway speeds
Haven't brought it to the dealer yet.  I'll keep you posted when I do
2020 Crew Cab—Same problem; mostly on the passenger side, but sometimes on the driver side. Nearly constant at 85 pushing headwinds or crosswinds. So loud it drowns out the stereo. Wife’s first 500 mile trip in the truck with me yesterday......she was not impressed, to say the least.
2020 Crew Cab—Same problem; mostly on the passenger side, but sometimes on the driver side. Nearly constant at 85 pushing headwinds or crosswinds. So loud it drowns out the stereo. Wife’s first 500 mile trip in the truck with me yesterday......she was not impressed, to say the least. I will try the mirrors in idea....sounds like it might be a temp fix, but being a “side mirror” driver, I need to find another fix. Thanks
One purpose of moving the mirrors from the old position in front of the glass down to the door shell was to eliminate this noise. Seems like it is airflow through the gap in the mirror pivot that is making the noise no mater where the mirror is mounted. Try putting a piece of tape over the front of the gap and see if the noise disappears.
So much for that engineering marvel that moved the blind spot created by the mirror to a different location, but did not cure the root cause of the problem.
Mine is noticeable on the drivers side, but not so bad that I have worried about a permanent solution.
Thanks, I will give it a try.
2021 Crew cab, load wind noise (sudden roaring noise then gone). In the body shop now. There is a strip of felt between the rear ends of the front fenders in the cavity behind the driver and passenger doors hinges. It is loose and twisted some all along the edges on the drivers side. All sealed on the passengers side. They say that most likely the problem.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
