2007 1500 6.0 vortec max
Anyone else have this truck?  I just bought it last December with 161,000 miles on it. I must say I’m very disappointed with it. It all started with a broken leaf spring coming apart on me which took out the speed sensor. Then the service four wheel drive came on and took a few days to finally shift back in to two wheel.  Then I had the lifter in the number one cylinder stuck. I just got it back yesterday and today the service battery charging system came up. The tires are shot but with everything else happening I’ve had to put off replacing em. So far it’s been a $10,000 nightmare
Has anyone bought the AFM disable devise to stay in 8 cyl? I figure the $180 for it is a lot cheaper than the $1220 it cost me for the stuck lifter
I had a 2009 vortex max 6.0, same exact truck except the year model, that I bought brand new and just sold earlier this year. It only had 82k miles on it when I sold it but more than half it’s like was spent with an 8” lift, 35s, 4.88 gears, and a custom tune by Blackbear Performance. I also towed a 9k lb camper for roughly 3-4K of those miles. The only things I had to do in the 10 years I had it were replace the battery, replace the front wheel bearing(most likely due to the 35” mud tires on 10” wide offset wheels), and I replace the oil pressure sensor a few months before I sold it. So I was very pleased with the one I had.
Bummer. Sounds like previous owner(s) didn’t maintain or treat it well?
I’d pull a valve cover off and if it’s full of sludge then get rid of it. If it’s clean, then it’s had regular oil changes.
I have the range device and it works great. Other forum members have had AFM lifter fail even when using afm disable device. Some have used afm for nearly 200k and have had no problems.
If there is a lot of oil deposits and sludge then it’s a ticking time bomb.
Service battery could be failing batt (get it load tested) or bad battery terminal connections or bad cables (high resistance in battery cable).
The half ton vortec max should run strong and put you back in the seat as it is tuned more towards power vs the detuned 2500 6.0
Good luck and keep us posted.
with 160,000 miles on it, you are at that stage where it'll nickle and dime you like crazy.  Same with any other vehicle.
    • Stan, this thread is specifically related to the Duramax 3.0, in the 2019-2026 powertrain subforum. If you'd like to talk about your other vehicles and offer anecdotal stories about them, please consider starting a thread in forum that pertains to your truck, or the other vehicles/ Off-Topic section if they are not a GM truck.
    • Can someone tell me where the video processing module is in a 2023 Silverado? I'm getting conflicting results that it's in the front passenger area or the rear passenger area behind the seat.
    • Yes I agree, its what amounts to free advertising to let people know about his UOA testing company, and not that there is anything wrong with that but certainly that is a motivator for putting out videos about the science of oil as well as other topics such as oil and air filtration etc. The interesting part I found with his last video is not only the physics behind the reason for the varying wear due to a diesels working torque range causing more bearing load and that higher viscosity oil is of benefit, it was also that the chemistry behind the GM Dexos 0W-20 and the Mobil Dexos licensed 0W-20 are far enough apart that its showing up with a difference in wear even though the two oils are matched in viscosity and in that comparison viscosity was not having the finger pointed at it.    There are a few youtubers out there or one anyway that I have watched a bit of who has gone through the pains of accessing various countries manuals for a certain engine platform and while in the US/Canada it may say use 0W-20 or what have you for some Toyota product, in some other countries it sings a very different tune for the very same engine with the typical traditional oil viscosity/ambient temperature charts to help choose which oil viscosity is correct for the conditions the vehicle will be used in and in some cases its taken an engine in a US manual that states only use 0W-20 as per warranty coverage and yet that same engine in certain other countries may have up to a 15W-40 etc oil option that meets the spec. Another words the guy who is driving through Death Valley or Phoenix and south weather at 120f is often being fed a line of bs by the US system that has forced vehicle companies to restrict the warranty to a specific low viscosity oil for anterior reasons as well as the long drain interval suggestions.    Thankfully youtube is free ( yet anyway ) for viewers to sift through information and of course comes with the good and the bad ( truth and lies ) and we can choose to turn off/not watch what a person finds is bs or just not interested in the topic.
    • No doubt... But, as someone who doesn't pay for his services, but who has provided a few views/clicks on his Youtube platform, the data around the Mobil oil testing I think does have some value including to "freeloaders" like me.   A lot of what he's doing is likely showing the OE's work in their oil selection, something that many of us had kind of assumed was true all along, a good balance of both excellent protection and efficiency.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
