99 Chevy Tahoe 5.7l. No start.
16 hours ago, Carla Jean simmons said:
Is there anything anyone can think of a sensor or anything that would cause the icm not send signal to the coil
How much is the ICM?  I know you said it checks out fine, but, sometimes things check out, only to be just a little bit bad.  You keep going back to that part.  I always look at how the part is that is likely is, and if it is less than an hour of my time, just replace it.
  • Replies 45
Time to look further in?while cranking test pcm fuse for battery voltage, sometimes spark and sometimes not,a feed is compromised?
the computer is reciving signal and sending signal to the icm but i have no signal coming out of the icm. I have put 5 different icm on it. I dont understand this at all
Either there is something wrong with the computer signal that you won't be able to see without a scope, or there's something missing at the ICM - a power, ground, or something else.
This page refreshed my memory - I was thinking you had a completely different system. This might help: https://easyautodiagnostics.com/gm/4.3L-5.0L-5.7L/how-to-test-the-icm-2
Too low is bad, so for me, anything above 1 ohm would work. Couldn't tell you what the spec is.
Here's something I should've thought of long ago in this thread - can't recall if it was brought up before or not ... but how is the crank position sensor? Is there an aftermarket one in there? Did the no start happen not long after it was replaced?
You didn't answer my question - how is the crank position sensor? Is it sending the proper square wave signal to the engine computer? New, OE, aftermarket ...???
Reason I ask is, I've seen many parts store units (like Advance Auto, Auto Zone, O'Reilley's, etc.) have stuff not work, or fail shortly after taking it right out of the box, brand new. Most of the time you'll never know they're bad without a scope.
Same goes for OE - lots of GM's parts are made in the same places that the aftermarket stuff is. Every so often you'll get a batch of bad ones. Gonna be hard to condemn that part without a scope, though.
If you can get ahold of a known good one - one that came off a running truck, that would be the best way to test it without a scope, just by playing swaptronics.
Have you tried back probing the white wire on the ICM, and touching it, key on engine off, with a test light connected to ground? Does it spark then? IF you can make it spark consistently this way, the problem lies somewhere between the ICM and CKP sensor, and engine computer.
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
