Fuse advice needed 2017 Silverado
bentarm13
Hello all!. Installing an amp\sub in my 2017 silverado crew LS. I want to use a fuse tap for the power on. Can anyone tell me what fuse is the sunroof, heated mirrors or heated steering wheel. As I have none of these, I figure I can use any of them to power on my my amp.
Check the driver side fuse panel. The cover has the fuse labeled.
If you're not replacing the factory radio just by a good speaker to RCA converter that has auto detect built in like an audio control lc2 just hook up the power and ground to it and it automatically see the signal and gives you a remote line for your amp. Also that being said most of the newer amps have auto detect built in so you don't need a remote line.
