Transmission? Or Transfer case?
Hello I have a 1988 Chevrolet 1500 4 x 4 pick up with 5.7 motor backed up by 700R4 tranny I put it in reverse it grinds if I put it in Drive first gear is fine once it hits 2nd gear it grinds if I manually put it in first gear and it doesn't shift into second it doesn't grind it only grinds when it hits second or if I put it in reverse also I put it in 4 low or 4 high and still does the same thing I don't know if it's the transmission or transfer case? Any Insider information would be greatly appreciated
I don't have any insider info on the 700R4 (I've just rebuilt a 4l80e), but from what you say, I would think it's the transmission, and it needs to be rebuilt/replaced.
If you want to have a go at rebuilding a transmission yourself (there are plenty of guides/videos on how to do it), I would suggest getting a used 700R4 (probably need a 4wd model, but I don't know for sure if there's a difference) from a junkyard and rebuild that, then swap it into your truck.  This will minimize your downtime, and may reduce the overall cost as it sounds like you'll need to replace some of more expensive bits in the transmission (actual gears) as well as various clutch packs/seals/bushings.
Otherwise, it's off to a transmission shop to swap in a rebuilt unit.
Either way, I would suggest putting in a new torque converter, as the old one likely has a batch of metal bits inside that will get dumped back into your new transmission when you fire it up...
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
