Need verification of heated steering wheel parts upgrade
Waffle34
  • Replies 35
sweet yea it sure looks like it.
Do we have dual airbag connectors like that?
From what I’ve seen, 1500 trucks have 2 connectors.
awesome thank you! i know i sound "needy" but im afraid of messing up my warranty or doing something that causes a weird electrical problem.
I had a 2017 silverado and first 10,000 miles was perfect, then one day hit a bump and gauges went out (everything went to zero), 6 error messages from service ABS stabilitrack, trailer brake controller, 4wd, and then steering input reduced please drive carefully message. was in the shop 4 times for over 3 months total. last 2 times the power steering actually went out mid drive (last time i almost took out the dealers garage door turning into it). left me stranded once as it wouldnt start because it didnt know where the gearshift was. Left the mechanic stranded twice haha. Got a call at about 9 am sunday morning as i gave him permission to drive it home over the weekends and test it out. Asked if its ever not started. I said no.... thats new...FIrst few times i thought cool they fixed it no biggie mass produced stuff has hiccups. but the 3rd time i JUST got back from a 1000 mile road trip around wisconsin. Literally 2 days later it spazzes out again on the interstate. I was like oh god what if it did this when i was up there? How the heck would i get home? How do you deal with a dealer thats never seen this shenanigans before?
long story short dealer and GM were in a no argument agreement i needed a new truck and fell under lemon law no questions asked. So my 18 has been good but approaching 10,000 miles again haha. (side note a few months after the deal was done i found my old truck for sale in Wisconsin - hope GM actually fixed the problem...)
so as you can see im quite nervous about messing with electrical stuff thats computer controlled...(Ive done many upgrades including clock spring replacement to add radio buttons on an 02 blazer and wired in tons of electrical vehicle stuff over the years so its not the physical DOING of it) This upgrade looks like a very self contained circuit, power from fuse to plug to steering wheel switch to heaters back to ground.
Doing these upgrades ever cause anyone warranty or dealer headaches?
when I took off my airbag to start this process (and realized I had the wrong clock spring) then I put it all back together, I got a "safety restraint service" warning at startup.  I'm still getting it.
I haven't tried to clear it out yet, but I'm  going to do that before I make the swap out for the heated steering wheel.
if it works, I'll just swap out the steering wheel and then have someone clear it out again.
if it doesn't work, I'll have it serviced and then try the swap out again.
Did you disconnected the battery and wait about 10min before taking the airbag out? That’s strange I’ve taken my airbag out twice first time to swap my dash out and second to add the heated steering wheel.
With the airbag (SRS) system, it usually goes away once all factors of the “system” are restored. Double check that all connectors are in place. The clock spring is sensitive. If you rotated the clock too much (had one customer that was messing with clock spring like a fidget spinner), the inner workings of the clock spring (if “unwound”) could have been damaged, could cause the CEL. Notice that orange that has the broken? That is done once it is installed. It prevents one from spinning the spring out of whack.
yes, probably 30 minutes with the interior courtesy lights "left on" during that time period.
I never removed the original clock spring or disconnected anything from it besides the airbag.
it's possible that the air bag plugs weren't re-installed properly (I did remove them to take a picture), but I'm usually pretty thorough about that kind of stuff.
Yeah I would double check make sure they are properly seated in the connector. Wonder if this is a new feature of the 2018 k2xx as mine is a 2014 lack some of the Sercurity feature the newer trucks have?
i sure hope not. I dont see how it could. Can you even physically install the airbag wires to the airbag like criss crossed?
Ok... so i installed the clock spring and wheel this morning.
A couple things:
When I removed the airbag, I saw the issue with my restraint system service message..
I didn’t push down the safety clips..
(So it was ON ME, not a function of just removing the airbag.)
When removing the clock spring it’s pretty tough to remove the airbag connector from under the dash. I WOULD recommend removing the connector from the Christmas tree clip before trying to route it out from under the dash.. (I left the clip in place and just reused it for the new airbag connector..
My airbag connector ran under a wiring harness that is clipped in using another Christmas tree clip. I could see it best by looking left of the interior drivers side fuse block, but in order to reach it, I had to run a clip removal tool up from the footwell to get the clip removed enough so the airbag connector could slide under it..
(Wide view, focus on the light gray zip tie in the top center of the photo)
(Tele view showing the shiny airbag harness “under” the fleece wrapped harness. The Christmas tree clip that has to be partially removed for clearance is connected to the light grey zip tie)
It took me longer to get the airbag harness out than it did all the other steps in the process.
Bottom line, mine still doesn’t work, I must be one of the ones who do not have power on the heater connector.. I know there is a work around, I’ll research it..
But no more air bag message now that the clips are fully in?
I still need to get under mine and figure out how to get 2 test probes on the dang pins while laying on my back, flashlight positioned and meter positioned so i can read it...
Will try with some skinny test clips
Correct no “service safety restraint” on startup any longer.. one clip was mostly depressed, the other one was about half depressed..
100% my fault..
100% my fault..
Glad u got that taken care of ??
Thats good, i finally got some small enough test leads clipped on the pins. I have no voltage either. (seems weird since i do have heated seats, heated mirrors, and remote start...) I will have to rewatch the youtube vids to see what is needed to do.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
