Letter from GM regarding fuel injectors on 6.2L
DRH
My apologies if this has already been discussed.  I searched the forums, but didn't find anything mentioning a letter from GM.
My wife drives a 2017 Yukon Denali.  6.2L engine.  A few months back we received a letter in the mail regarding a possible issue with the fuel injectors.  It wasn't a recall, just a notice that there could be an issue.  It mentioned that if the truck idled rough to take it in to the dealership.  She needed the brake recall performed anyway so we took it in.  When I mentioned to the service tech that her truck has been idling rough and has white smoke coming from the exhaust under acceleration he said it could be the injectors.  I mentioned the letter and he didn't seem to think that GM had acknowledged any such issue.
Of course we can't find the letter now, and I'm worried the dealership is going to fight me if there is an issue.  Even though the truck is still covered under warranty.  Did anyone else get one of these letters?
thanks for the help!
so after digging a little more, I see that this letter has been mentioned.  I guess GM called the 5.3L enginge a 5.7L in the letter.  Some mentions of the letter state the issue is VIN specific.  Any ideas on where I can look to see if my VIN is included in this?
Not applicable in Colorado.
This special coverage only applies to vehicles in these states: California, Connecticut, Delaware, Maine, Maryland, Massachusetts, New Jersey, New York, Oregon, Pennsylvania, Rhode Island, Vermont, and Washington.
Truck is registered in Oregon
So the dealership tells me one the cylinder heads is porous and leaking coolant, which is causing the white smoke from the exhaust.  They are now keeping it for a week to get parts in and repair it.  Stay tuned.
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 686 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
