Been missing for quite a while, but I have a 14 Sierra SLT crew cab. When I first test drove it, the sun roof quit working after venting. No issue, they’ll have to fix it. Bought it Saturday and it started working on the way home, Monday back to the lot bc it quit again. Sat for over a week trying to trouble shoot it. It messed up once and they did a relearn and worked fine for them after. Picked it up, next day same thing. Waited for ext warranty to kick in and brought it to the GMC branch of said dealership. It had worked perfectly every freaking time they try it.
here’s what it does. When it’s slightly warm out, on a cold start after sitting in the sun for hours, it’ll open and not close, or it won’t function at all, OR the buttons will all do the same thing. Drive it for 30 minutes or so, and it’ll either work right, or the buttons will again do all the same thing. When it doesn’t function, you can hear A clicking right behind the buttons. Do y’all have any ideas what I can do so they can try to diagnose it? Any idea what it may be so I can try to fix it myself? I’m fixing to contact GM as the dealership wants me to pick up my truck since it’s “working properly”. I love my truck, but the sunroof was the main reason I got it. Sorry for the long message, and thanks in advance!!
ETA: I have searched high and low for this problem, and there’s no one who has this same problem. I’m not blowing fuses at all, I don’t have the console charge pad, no the sliding back glass.
Edited by Alexquade
Not possessed.  I have the same issue on my '14 High Country.  I've narrowed it down to heat.  When it is cool outside and/or no direct sunlight heating up the sunroof, it works perfectly.  This is why the dealer was unable to reproduce while it sat in their service bay.  And when I picked it up in the morning, no problems.  Later in the day, it produces all sorts of stuttering and stops.
I've had an independent shop test as much as they could get to without taking everything apart (apparently it involves the curtain airbags).  They believe the problem is with the motor.  The switches checked out just fine regarding voltage.  Haven't had a chance to hand it over to a specialist yet, as I need my truck on a daily basis.
And yes, I signed up just for this post.  I've been researching this problem for quite a while now.  There's one other post on this forum from about 4 years ago that describes the same issue, but there was no resolution.
How old is your battery?
That I’m not sure. Definitely wouldn’t hurt to check it, I guess! Thinking about it now, first start before the test drive, it struggled a little bit to start.
The factory batteries have a horrible life span.
There is a post on her about someone's turn signal not working, I suggested the battery, he swapped it and problems are gone.
Another poster had an electrical problem, replaced battery, problem gone.
I know when the battery went bad in my 14, I had all kinds of strange issues that went away with a new battery installed.
Not here.  Found the problem before battery replacement, and still have the problem after a brand new battery.  Not to say it won't help the OP, but not I.
Had the battery checked, it checked out good, 100% charged.
I would still check the loom that runs through the center console, I have had the lid apart putting on the chrome handle latch, and they do not do a good job of protecting what it rubs against as you open and close the lid. That seems to be the problem with the rear slider failing, but i could be wrong on the roof being part of the same loom.
Don't think the charger makes a difference if you have it or not, just something else that is part of the wire loom.
I’d have the loom even though I don’t have the slider or charge pad? Is it in the console itself or in the lid??
I have a video of it, if someone could let me know of a video host other than YouTube that would work here.... I have a new switch on order. Just waiting for it to get to my house. Will it be plug and play, or will it need to be programmed???
At this point I would ask the parts department at your dealership if they can provide the schematic of the sunroof, for parts, wiring and so on, just so you have a better idea of where to look.
Not sure why I haven’t seen this post before, but this is my exact problem. I’ve changed the switch and it didn’t help. I will contact the dealer again and relay more info before I start doing more myself since I have ext warranty. I’m not the greatest with wiring or taking stuff apart! Thanks for confirming I’m not the only one having these issues!!
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
