not three wishes, what three cars?
SnakeEyeSS
IF you could buy THREE(each of cars/trucks), (LIMIT) cars in the world, any cars AND trucks, what three would you own(if oyu don't get it look at mine for an example). They MUST be a 2004 model year car.
Review of rules:
3 cars max
2004 model year only
STOCK ONLY don't list mods, or said 2004 Z06 with an s/c blah, blah
That it so far. My choices are:
CARS:
BMW M3, Red
Corvette Z06, Torch Red or Milleninum Yellow
Ford GT
TRUCKS/SUVs:
Chevy 3500 single rear wheel with Duramax/Allison, Crew Cab, shortest bed I can get
Ram SRT-10
BMW X5 4.8is (not official yet, but they are supposed to make one by mid year)
if X5 4.8is isn't made, then a
if your turning red at the sight of the dodge, note I picked a Chevy for an actual truck, the SRT-10 was picked for what it is, a toy. And its the best "toy" truck on the market in 04
#1 Hummer (not and h2....a real one)
#2 Cadillac Sixteen
#3 A Harley
Sorry I didn't follow the rules...but I don't want 3 cars and 3 trucks, I want those... :mad:
Cars:
1. BMW M3, black
2. Corvette Z06, black
3. Porsche 911 Turbo
Trucks:
1. GMC 2500 HD, Duramax, Allison
Can't think of another truck I want.
Well, if it HAS to be an '04,
'04 F-150 regular cab long bed w/ HD payload pkg. in XL trim with AM/FM/CD and the vynil bench being the only other options. It would be dark green with a tan interior.
'04 Dodge Dakota base model regular cab 4WD w/ 3.7, manual, and a 3.92 rear. It too would be dark green with a taupe interior.
Don't need no cars.
Can something that would be shipped from Dodge w/ the truck and installed at the dealer be a factory option? If so, throw in an AM/FM/CD sound system.
# 1 - Rolls-Royce Phantom
# 2 - Bentley Arnage
# 3 - Ferrari Enzo
And so close I have to include it .... 2004 Maybach Maybach
Trucks / suvs
# 1 - Hummer (first one)
# 2 - 2004 Silverado 2500HD crew/long dmax 6spd
# 3 - Mercedes Benz G-class
Porsche GT2
Lingenfelter twin turbo 427 C5 Corvette
4 second rail car :mad::)
Trucks: H1, Military 6x6 (can't think of name), one of those tandem axle tractors that compete in trator pulls.
Porsche GT2
4 second rail car :thumbs::D
6x6 isn't that the duce and half?
Trucks:
3500HD dually crew cab long box loaded Dmax/Ally...
H1
2500HD crew cab long box (funny current truck... :D ) Only upgrade I would have done is the DMax/Ally
Cars:
Dodge Viper
Chevy corvette
Mustage GT
All in a dark green color... :) Can't beat dark green..
Whats with everyone wanting a crew cab short bed...? I love having my long box.. Get some real good looks going down the road.. :D
Whats with everyone wanting a crew cab short bed...? I love having my long box.. Get some real good looks going down the road..  :thumbs:
Its the sad state of the times. No one uses a truck anymore except to haul the kiddies to school (hence the crew cab), no one buys enough groceries to fill up a longbed either.
Back to my good ol' piss off everyone comments again. :D
Trucks:
2500HD Extended cab, 8.1, Long bed
Ford Superduty PSD (also ext. cab long-bed)
H2
Cars:
Corvette ZO6
GTO M6
Mercury Merauder (Are those available in '04?)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
