I am going to have it diagnosed during the week it runs a little better but it still has a hesitation off subject I have a manual 2-speed transfer case 4hi 4lo what kind of fluid does that take I don't think it's Auto Trak I think it's Dex 3
Yes, it should be DexIII.  And you want to find an actual DexIII fluid, as while DexVI is considered compatible, it was found to leak past seals when put in earlier vehicles.  GM changed their seals when they switched to DexVI.
Also check fuel pressure at the rail, both at idle and when the engine is revved up.  Pressure should be right around 60 psi, just going lower when the engine is revved, but quickly returning to full pressure when the speed levels out.
When I first got my truck, it acted similarly, and for me, it was the fuel pump failing, exhaust leak due to broken off bolts, and O sensor.
Davester, how was your truck when you got it and what year mine is o4 with 185000 miles, just for a work truck but when im on the highway in 4 th with the converter lock under a load it craps out unless i kick down to 3rd its the shaking thats really bothering me plus the idle seems low and rough, thanks you guys
I have new fuel pump, new plugs, new intake gaskets and a new map sensor.the guy i got it from said he put a new fuel pump in but what kind i dont know.  With my last work truck it was an 09 i was told only use delphi pump
When I first got my truck, before I fixed it, it would drive ok, but just guzzle gas, as it both had an exhaust leak, and low fuel pressure, so the ecm was dumping as much gas as it could into the engine.  It shifted fine, but had no power (as the gas was being dispensed, but poorly, as there wasn't enough pressure to atomize it properly).
I think the main things that fixed it for me were:
-replaced fuel pumps (mine has two, only one is really important)
-fix exhaust leak by replacing broken exhaust bolts and/or installing clamps for the ones that couldn't be readily fixed
-replaced MAF and upstream O2 sensors
I also replaced other stuff, but I don't think they had much effect (as in, they weren't an actual problem):
-knock sensors
-intake manifold gaskets
-spark plugs
-MAP sensor
Jasta update you guys that helps me out it was the number 7 injector and the evap purge line was broken where it goes back behind the engine so truck runs very well thank all of you for your help
  • 3 years later...
04 silverado 1500- yes it does have a regulator first off. You have to take the spider box off and it's on the rear side of the injector rail casing held on by a double c clip, problem is, they don't have the one that comes out the 4.3L motors anywhere. The ones they are selling as 4.3L regulators, are for a different v6 than what's in this truck. And everywhere sells only the one. I am looking for the exact regulator I have in my hands. Anyone been down this rabbit hole yet? Or do I have to chase my tail to find one. Please respond. Thanks
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
    • The average lifespan of automobiles on the road is increasing - here's why
    • Typically it is the Torque Converter, I have a 2.7L Trail Boss and between 25-65 MPH at 1300-1500 rpms under light throttle it has a shudder which I almost consider and bobble or a gargle sound. They replaced my TC but it did not help any, others say it has fixed their issues. It has been back twice now with no fix after.
    • Still $3.01 with even more places at this price
