On 12/21/2019 at 5:45 PM, Dunn said:
I don't understand why these UCA cost so much, know theyre better and stronger but still some are $800 for pair....I just don't see why theyre so much...fabricating tubular steel doesn't cost that much, ball joints and bushings cost nothing.....you can get aftrmrkt OEM ones for nothing, not as strong but 4-5 times the cost?
Just unnecessary bling.
ReadyLift SST kit with the UCA’s, 305/55/20 with 0 offset wheels. Basically 33x12.5. Barely rubs inner front fender well at full lock. Good articulation and UCA clearance. No way the stock +27 offset would have fit, it would have rubbed big time.
8a720f384c21050a0ddce0eb7632e5a8.plist279ae7e79353780b48f19091264ea27d.plist0dbffdbfdd2cbb17d2a1c640f22fed0a.pliste6837f3e6e7f08e8821575d0580ab7b1.plist
Sent from my iPad using Tapatalk Pro
  • 5 months later...
I believe a 305/55 is a 33x12 right? I think I’m gonna copy your offset/size man, looks great
I have the same setup.  305/55R20 on 9" (+2) wheels on ReadyLift SST.  No rubbing.  We tried 10" (-19) wheels and had rubbing on the fender flare with both 305/55R20 and 285/60R20 tires.  Changed to 9" (+2) which brought the wheels in slightly and no rub at all.
Yeah, you’ll love it. And thanks!
Man I was hoping for a 10” but these 9” set ups look good and I’m trying not to rub
I was able to see the truck with both the 10" and the 9" wheels and there really wasn't all that much of a difference.  Let me go and look for some pictures.  I think I have pic's of both.  I will also try to take some from in front and behind with the 9" to show how they tuck.
This is with 10" (-19 offset) and 305/55R20.  Also this is without the fender flares which come out an extra inch or two.  This setup rubbed slightly according to the dealership.  I didn't get to see it in person.  Once the flares were installed it rubbed badly.
IMG_5411.thumb.jpg.5a0d95f7ec2740dbb7d025fae8f28bbc.jpgIMG_5412.thumb.jpeg.ed9899dfe468e79a83cc38f10c68866e.jpeg
Edited by NolaHorn
  • Thanks 1
For some reason it won't let me upload the picture with 285/60R20's on 10" (-19) with the flares that rubbed badly but you can see the pic in my thread on "AT4 Step by Step modifications"
  • 2 years later...
2 inch sst added grabbing some 285/65r20. I'm running 275 right now no rub at all ever. I can also run 4wd auto with no vibrations or grinding. Rides amazing and way better than stock. Cv angle is good its just on uneven ground in pic.
    • Because single shot injectors are ancient and multi hole injectors provide smoother running engines and sharper throttle response due to the fuel being atomized better..the best lead I have is a 24lb blue top injector almost everything matches up but the injector will put out about 26lb/hr which is just outside the gm threshold.figured id ask here to see if there was an absolute answer
    • Why is my question?   Any change in injectors requires a tune. Unless you are going back with the OEM part number or a newer part number of that same injector.   Any size difference or type difference like the EV6 style injectors all have different injector data for them. And there is no EV6 injector that matches the factory 25 lb/hr size that your truck comes with. I've been messing with these trucks and tuning them for a long time and what you trying to do doesn't exactly make sense to me.
    • My 6.6 gas lt8 had lifter noise with 28000 miles bought new 2026 and while driven to dealer it threw #1 rod bearing “HD my ass” good luck with yours i hope it don’t turn a rod bearing!
    • When a condition becomes a business model.    https://www.gm-trucks.com/gm-truck-suv-incentives-pricing-2026/   Zane posted this in "Latest Articles".    The honest bottom line   Truck buyers have spent three years assuming this is a temporary condition that will break once inventories normalize. GM just presented it to investors as a durable strategy, on a chart, as evidence of good management.   Inventory did normalize. GM is at 511,000 units and squarely inside its own 50 to 60 day target. The discounts still did not come back, because the low incentive number is the goal rather than a symptom of shortage.   Plan your purchase around that reality instead of waiting for it to change. Follow our ongoing GM News coverage for pricing and incentive changes as the next-generation trucks land.
    • Thought it was raining this morning when we woke. Nope. Dew point was over 80 F and humidity 98%. Zero visibility distance. Everything was 'sweating'. I've seen rain come out of clouds but never out of Pepper or the tree trunks.    Wicked storms just missed us sliding off to the east but by blocks. Heat index about 110 F with air temp in the 90's.    This is  our third wave this month of multiple days of this type of weather. And yet the grass is going dormant and the ground is cracking this side of the street and water up the the hood opposite. Just weird stuff going on.
