2000 Silverado 5.3L fuel pressure still low after new pump and more...
2000 Silverado 5.3L 2WD 1500 RCSB w/ ~165Kmi - all stock
Fuel pressure still just under spec after new pump and more...
I replaced the fuel pump (AC Delco OEM) and the new pump made only a slight difference and pressure is still out of spec. The new pump pushes about 2psi more pressure and draws 2amps less.
Spec per Haynes:
55-62psi key On / engine Off
Old pump:
52psi key On / engine Off
48psi at idle
56psi at idle when you pull the vacuum line from the regulator
Amp draw 8.5amps
New pump: 54psi key On / engine Off
Flutters between 48-50psi at idle
58psi at idle when you pull the vacuum line from the regulator
Amp draw 6.3amps
Fuel pressure regulator vacuum line is dry and no obvious signs of failure / fuel leakage and also see the readings above with the FPR vacuum line removed.
Measured the voltage drop for each the power and ground circuits and that checks out as well. Voltage drop is ~0.1v on the ground and ~0.5v on the power with the truck running. Battery only (i.e. not running) ~0.1v on the ground and ~0.4v on the power. Measurements taken from the battery post to the pump connector. Pump is also getting 14v while the engine is running (~14.6v at the battery).
Removed the fuel filter and blew out the supply line from the pump back to where the filter would be then switched sides and blew out from the supply line at the rail to where the filter would be and it did not make any difference. The fuel filter was changed about 2 months prior to the new pump in an effort to fix the low fuel pressure but did not make any difference.
So all that and the fuel pressure is still lower than the spec. of 55-62psi key On / engine Off.
What should I try next?
What does your fuel pressure normally read key On / engine Off or at idle for a 5.3L of this vintage with return systems?
Thanks.
What caused you to check the fuel pressure? Does it run poorly? Do you have misfires or fuel starvation issues?
Truck completely died twice a few months ago on two different trips. Once while accelerating to get on the freeway after I had already been driving ~30min without any issues and once while idling in park, again after I had already been driving ~30min. No misfires or trouble codes I am aware of. Other than those two times the truck has always run great and still does today. Test driving after the new pump I nailed it going ~30mph and after down shifting to 1st it spun the tires until shifting into 2nd, so seems healthy.
You might consider replacing the FPR.
And you might consider testing fuel pressure when the engine is going faster (that was the problem with my truck, at idle the fuel pump could get it up to 55 psi, but once the engine was going faster, the pressure would drop way down).  Note, the pressure may drop for a short time as the engine is speeding up, but should quickly return to full pressure once the rpm's become constant again.
    • I had an 88 K1500 with a 5.7 that had those symptoms, I know totally different, it ended up being the ECM. Once you get the fuel system fixed if it still runs lousy you may want to investigate that. it didn't set any codes, stalled ,ran rough at times etc
    • Congratulations Isttype, on your gmc. Really like my 2024 2500hd sle doublecab now with 85,500 miles.  I checked the oil today at 4800 miles since last oil change and barely reading on the stick.  I don't care if GM says it's Acceptable adding a quart every 2000 miles because that is 100% BS, It is not a 1966 Harley Shovelhead! Sounds like it's setting up a future failure like I had with my 1500 6.2l. Other than oil consumption problems, I really like the 6.6l gas and 10 speed is really nice.  Towed a light 4000 pound trailer last week and averaged 14 mpg.  I was pretty impressive that a 7300 pound gas truck did 14mpg towing, Later-
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • I don't think you will need a split, separate product, etc., the OBD port should be able to deliver everything you need. Since your device would be plugged into it all the time, it wouldn't miss anything.    Hardware in this case will be the easiest part of your project - ELM 327 devices will already deliver all the data you need. Reporting/software is where your advantage/marketability is.
    • I do too. I’ll never be stuck again 😂
