Vacuum pump now covered for 10 yrs/150,000
SILVER SLED
This may have been covered already but I didn’t see anything.   GM has extended the brake vacuum pump for 10 yrs and 150,000, which ever come first of course.  Bulletin# N182202780-01.  Sorry if it’s a repost.
Recall done on Thursday, pump went on Friday.  Got around to taking it to the dealership a week later, and fixed no problem.  All it cost me was my time and a signature.
  • 1 month later...
Now for the exploding window recall / fix in the USA.
I pulled the fuse in mine since i rarely ever need it and its always automatically on in low temps.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 290 Guests (See full list)
