2015 High Country 6.2.  Had torque converter replaced about a year ago to correct tcc shudder.  Started again a few days ago and took back to dealer.  They performed bulletin 18-NA-355 (flush transmission w/ Mobil 1 ATF and said to drive for 200 miles for full effect.
Just wondering if anyone has had success with this procedure to correct tcc shudder and hard shifting.
Thanks!
Was your shutter at 55-75mph off and on where the rpms raise a little and the steering wheel shook in your hands?
My '16 was flushed with some sort of new and improved fluid. Drove great for about 1000 miles then It came back.
Sent from my SM-N975U using Tapatalk
  • 6 months later...
Not really what I was hoping to hear. Mine is going in on Monday.
Anyone else with an update on this TSB?
Thanks,
Jon
Sent from my Pixel 4 XL using Tapatalk
  • 4 weeks later...
They replaced my torque converter under warranty. Doesn't exactly give me a warm and fuzzy but they took care of it.
I was under the impression gm stopped all tsb's for 8spd/tcc. The class action lawsuit for the 8l90 got thrown out because gm stated that their warranty covers manufacturing defects not poor design. After that, all work on 8spds was cut immediately and they stopped trying to fix it. I dont have the link for that specific tsb but do a quick search on google and you'll find it.
  • Sad 1
Pissa. More great news. Thanks for the info.
My TC was replaced because my truck is CPO. Let's hope if it happens again it's before 100k...
  • 1 month later...
Just had mine flushed today in accordance with TSB 18-NA-355.  My 2017 Silverado High Country is also a CPO.  Should I have asked for a torque converter replacement?  It seems to be driving great now after the tranny fluid flush and fill.  Thanks.
Chris
Chris
It may be ok but down the road the TC will likely need to be replaced... based on what I've read from other people's experience anyway. How many miles do you have on the truck?
My dealership did 3 things all at once to fix the shutter for me: triple clean flush with new tran fluid, replaced TC, and reprogrammed the tran with an update from GM. This was done last year and while it was technically outside my warranty (miles) they got GM to cover the entire bill. I've driven ~35k miles since this was all done and have not had the shutter return. Sorry, cant say if it was any one of those in particular that fixed it. The dealership said they didn't want me coming back after only doing one of those so they did all 3 at once.
On 8/19/2020 at 6:15 PM, Sierra Jon said:
Chris
I agree.  I have read the same remarks.  It's a CPO, so I am hoping if it does need to be replaced it will still be covered under warranty.  It currently has 38k miles.  Thanks for the reply.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 426 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
