2012 Front End Clunking at low speed
Whenever I am driving at a low speed of 30 mph or less, the front end passenger side of my truck clunks like crazy. Gravel roads make it clunk so bad i cant isolate where its coming from. I have replace struts, control arms, sway bar links and bushings. Only has 68000 miles. Has anyone experienced this and found the cause? Also it seems to only do it when driving straight, not when turning.
Look at everything under the hood. Everything bolts to the fender on that side and look at the engine mount area, see if anything is loose in that area. Could be something other that suspension.
Check the control arms, bushing and bolts, they are supposed to be torqued to 140 ft lbs.  Get that side off the ground and check the 5 bolts holding the strut assembly in place.  Check the swaybar bushings, not the end links, but where they bolt to the frame, those bolts can break if they get too rusty.
    JJ_Denali2020
    JJ_Denali2020
  • Who's Online   1 Member, 0 Anonymous, 673 Guests (See full list)
