It looks like I am dripping transmission fluid from the transfers case at the drain plug.    I ordered a new plug and will drain and refill with new Dextron VI.  When I install the new drain plug, should I coat the outer threads with black permatex?  Will this make it very difficult to remove the plug should I need to in the future?
Thanks,
First, are you absolutely sure the drain plug is leaking, not that fluid is coming from further up.
Second, with the drain plug out, after all the fluid is out, really clean the area and check if the housing is cracked, say, from someone overtightening the drain plug.
Third, check the case to see if it has a hole where the "gm pump rub" problem rubs a hole in the case.
Fourth, I would suggest not putting permatex on it.  Just get a torque wrench and use it to torque it down to 15 ft/lbs (that's from my '04 sierra full-service manual).
Fifth, the proper fluid for it is DexIII.  Find some that says it is DexII.  DexVI was known to cause leaks when put in older vehicles (particularly, made prior to when DexVI became a specification), as the seals weren't designed for it.  Even in '06, the transmission was specced to get DexVI, but the transfer case still was supposed to be filled with DexIII.
Owner's manual does call for Dex VI.  I'll have do take another look, but there wasn't any obvious fluid leaking down from above the plug.  This is on a 2012 sierra.
Oh, I was looking at the truck at the bottom of your post...  Forget the thing about pump rub and DexIII, and the torque for the drain plug may be different for your transfer case.
You gotta use thread sealer on that plug.  Its white stuff in small white tube made by permatex.  It isnt any kind of loctite.
Just be sure to work the stuff around in the tube before you use it.  You know how mustard always dumps water on your hotdog before mustard comes out?  This stuff kind of does the same.  So, I always squirt a little on a towel before I use it.
Looks like the housing is cracked.   I was able to see the crack after putting the new drain plug in.  I drained the fluid, cleaned it with  brake parts cleaner and sanded the area around the crack.  I put on some JB weld and holding out hope that this will seal it.
It looks like a new housing is about $250 on rockauto.com.  ACDELCO 19302452 GM Original Equipment .  Any idea what I'm looking at to get this fixed?
Part image
Sorry, no idea.  I know for the previous generation truck (GMT800's), it's
-remove the transfer case (the case to transmission bolts SUCK, particularly the one at the very top)
-remove the VSS sensor
-unclip a retaining clip for the rear bearing
-remove all the bolts around the edge,
-then the housing splits (takes some careful prying to get rear half off the alignment pins)
-clean off all the old sealant between the case halves
-put free sealant (anaerobic flange sealant) around the inside edge of one half (enough, but not too much, as the excess that squeezes out on the inside winds up trying to plug the inlet screen to the oil pump)
-put the case halves together, on the alignment pins and torque them down (I do it in 2 passes, first time snug, then second time torqued down to the right value, in a criss-cross pattern)
-put the retaining clip on the rear bearing
-reinstall the VSS sensor
-install tc into vehicle and fill
Removal/installation, you really want a second person to help, even with something like a transmission jack to lift it, as it doesn't have a nice flat lifting surface and it has to be rotated in 2 directions to get past the crossmember just behind the TC.
Yours is different, in that it has those two visible machined sections where something bolts onto, and perhaps there's more stuff to bolt on to the inside.  As well, there are likely bushings, seals and bearings you will have to install in that cover before it can be installed, that you will also have to buy, as typically you will fatally damage them trying to get them out of the old case half.
You might find youtube video's on how to do this job, and maybe study online parts diagrams for the transfer case, as you've identified the specific transfer case you have (hopefully!).  Most like, info about your TC is less commonly available than it is for mine, as the GMT800 TC's had the pump-rub problem, so it was pretty commonplace to remove them, do a pump rub fix that involved splitting the TC, and then reinstall them.  Later trucks didn't have that problem, so people only dealt with the TC when they failed.
Finally, going forward, find out what torque value to use for the drain and fill plugs, so the new case doesn't crack again...
  • 1 year later...
Kenneth, did the JB Weld solve your cracked housing problem?
I have the same crack from a tech over tightening the drain bolt on the transfer case.
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
