Brake Pads
Hello, I've got about 5500 miles on my 2019 AT4, my dash is telling me the front brake pads are at 25% and rears are at 50% ...is this info accurate / trusted?
Doesn't seem to make sense, I don't brake very hard that often.
Did you get the recalls done? The brake pads are fine w plenty of line. Mine said the same until this past Friday. Now they’re at 90%
TSB PIT5695A Brake wear readouts recalibrated . Wear Indicator reset to 100%.
    Bulletin 19-NA-191 says Software update and Brake Pad replacement but only for Cadillac CT6.
I specifically mentioned PIT5695A to them when I had my service and it was reset to 100% afterwards so you'll probably have to go back in to get them to reset it.
12 hours ago, PyroTeKniX said:
I did have the "Brake System Malfunction Warning" N192268090 recall done recently, they forgot to recalibrate it I guess?
The N192268090 Recall I believed had nothing to do with the Brake Pad Life Readout. It had to do with ensuring the Brake Fault lites would come on when a fault existed. Ensure PIT5695A is completed to fix the Brake Pad Readout.
