@Yep,
 I ordered the cluster from white automotive media, the steering wheel I ordered from GM parts warehouse and the wire to make everything connect came from the Harness Dr.
I just want to confirm with all who did this...
Did this add volume control as well, via the steering wheel?  Thank you!
2 hours ago, Vradcliffe said:
Yes, this added the the volume control on the back right of the wheel as well as adding the skip track/change station on the back left of the wheel.
Thank you!
Are you able to also let me know what steering wheel PN you ordered?  Appreciate your time!
5 hours ago, Vradcliffe said:
Here you go…this is the steering wheel I ordered and am now using.
Awesome - thanks again!
forgive me if I have not found the thread on it yet - but has anyone done this swap AND included adding the heated wheel?  I imagine for that , it would be a spring clock swap as well?
the prices that are going on right now , and my recent career change has lead me to think I'm likely going to buy my 2020 Custom 3/4 ton out at the end of my lease, and this is a have to mod for me if I'm keeping the truck!
I did not add the heated steering wheel. From my understanding, that does require the new clock spring and maybe an additional harness down by the kick board. Because I live in Southern California, that’s just not much of an issue for me lol.
Are there any youtube videos or writeups on how to do this swap?
 Here you go
On 6/19/2020 at 9:33 AM, Jhoupe said:
Has anyone tried this yet?  I have a 2020 2500HD WT that I want to do this too.  I have order the steering wheel harness, radio switch and control.  Will be here Monday, I assume it is doable.  I wanted remote start, so I ordered the kit from GM Parts Direct and the only thing that showed up was 2 fobs and an authorization code.  Says you just need locksmith to reprogram (Im scheduled so we'll see)
I have a 2023 Silverado 2500HD Custom and wanted to add a remote start.  Found this one and it works awesome using factory key fob (lock three times).  Start-X Remote Starter for Silverado & Sierra 1500/2500/3500 2015-2023 || Plug N Play || 3 X Lock to Remote Start || 5 Minute Install || USB Updater Included || Zero Wire Splicing! (amazon.com)
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 162 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
