Truck has 67000 miles stabilitrak lights brake lights abs I loose power steering truck will skip radio will cut out and truck will eventually throw a check engine light and loose overdrive and what seems to be first gear ...G218 has been done as we’ll as other side local shop put a bcm in at 526$ still have the same problems which seem to show more when it’s wet and cold any help is appreciated
Check all of the grounds..  mainly the battery ground. This is a common issue with these trucks after a few years.
I have read on FB there is a ground wire under the drivers A pillar that when the truck was built it’s half on the cab insulation and half on the truck. If you pull the A pillar towards the dash speaker you can see it. Just a thought
Thanks will do
The negative battery cable is a culprit to many grounding issues w/o any signs of it going bad.
Run a second ground wire from Negative terminal across the firewall to the ground bolt next to the brake booster. About $15 fix from parts store.
This may fix some issues, if not you are at least covered if and when the original ground cable acts up. This fixed all my ground issues.
I also heard the driver side fuse block tends to corrode on the underside, you may want to check that. I think it can be removed, i never tried.
I had the negative battery issue with my K2 2500. Had the same symptoms as you more or less, told me two week wait to get it looked at. I said to them its not really safe to drive when your headlights cut out at night. So I took it into my shop and the neg cable was loose on battery and ground was a bit loose on frame so I put some grease on it and tightened it up. Was ok after that. Good luck.
All grounds checked and cleaned took to dealer and they replaced positive and negative cables 450$ still having the same issue 1000$ this month no luck
Man your dealer kinda sucks. At my dealership, if it doesn't fix the issue... You do not pay. They should have done a loaded voltage drop test on your battery cables before replacing them. Ask them to clear all the codes please and then when it happens again ask them if they will hook up GDS2 and give you a report on all the codes that set after it came on. Come back here and post ALL (doesn't matter how trivial you think they are) of the codes. I am the Electrical specialist at the dealership here. Been that for the last 20 years. This is what I do. Lol
They still have it and if I remember right they said it was loosing communication to just about everything  but I will ask thanks wish you were in ga
On 2/28/2020 at 12:39 PM, BlaineBug said:
I'm confused, what's wrong with the original battery cables?  You don't see these battery cable issues on vehicles that are 40 years old, seriously.
You can have issues with batter cables. We have had alot of issues with them from 2007 - 2013. The voltage drop within the cable (resistance) gets above 1volt. so when you're cranking, driving, ect you already have 1volt of drop. So if you battery ever drops to 11volts, in actuality you only have 10.
Can be a common issue, but there are ways you check without throwing parts on vehicles.
I understand that, normally I've seen issues with loose terminals on the battery posts or a loose connection between terminal clamp and cable.  What are other causes of high resistance in wiring besides corrosion beneath the insulation or a break in the wire that degrades a significant amount of the copper strands?
    jrogjr
    jrogjr
  • Who's Online   3 Members, 0 Anonymous, 837 Guests (See full list)
    • Average Assembly 4.8%   That's the likelihood of a light duty vehicle reaching 250,000 miles. Link below has the stats on this. Among pickups the 350 series (Dodge)  and higher (450 Ford) are most likely and nothing American built in the lighter trucks pegs a number higher than the overall average.  200K and up is the stomping grounds of Asian vehicles. Toyota Sequoia the leader at 39.1% probability.      https://www.autoweek.com/news/a68886903/vehicles-most-likely-to-last-over-250000-miles/   Likelihood drops dramatically at 100,000 miles of reaching even 150,000 miles. 250,000 is deep in the tail of the curve.    I've been told by the 'experts' that I don't need oils of the caliber I use. My high viscosity is damaging my motors. Ash content it to high and WILL foul plugs and kill cats and O2's. I don't need that much ZDP; my choice is over added and not cutting edge. I change it to often. I baby them to much.    Three Honda's reached 200K + and none used oil. All Red Line motors. All sold to friends or family. One Toyota reached 300K using oil, Pennzoil. Dizzy 300K using QSUD until it cashed the rings at 80K then whatever but often ever since. Did you know this engine still sports the OEM timing chain and is dead silent? Pepper spitting into the wind short of 200K, Red Line and changed often. Uses zero oil. A HPFP and a pinion seal. Still using most parts it left Fort Wayne with. So 50% of my vehicles have gone past 250K and 100% of the last half dozen past 200K. Of these two using "shelf oils' did so using abnormal oil and the four that used a premium boutique oil did not. There might be something there the experts have missed. 🤔
    • i dont know where you been reading...they make a top notch product..people say lots of great things about them..yes it can be difficult to get a hold of them when you need help sometimes put when  you do it is great service...   as for the actual question at hand i have the ccv mod and i vented to atmos in my case...I got my ccv from somewhere else but i have plenty of VSE product...for starters i use their tuning on my 22 duramax
    • It's not that it sits for extended periods. I drive it every couple of weeks. However, I did consider draining the DEF and replacing it.    Don't you get a "Poor quality DEF warning" if its bad?
    • Try draining the def and relacing with new if it has been sitting for a long time. Def does go bad after a little while.
    • Thanks @Viktorrocks15 if you are still out there.   I followed your instructions and worked out great, went to the scrap yard and procured 2016 escalade cluster, hud, bezel, and switch. Got lucky and found a Camaro in the u-pull with the HUD bezel.   I made my own harness with these diagrams: https://www.gmupfitter.com/wp-content/uploads/2022/10/23_Escalade_Escalade_ESV_Electrical_Body_Builder_SM_en_US_2022OCT25.pdf   I used escalade cluster because its the best one that will work IMO. Still need to get it programmed but it looks really good.
