Looking to buy a 2011 gmc with the 6.2
I am looking to buy a 2011 6.2 1500, I’ve gear that the 08-11 have a tendency to use oil because of piston rings. It has 125k miles, will I see oil being used in miles to come?
The Silverado/Sierra with the 6.2 in the NNBS body did not come with AFM/DoD. They just had VVT.
Burning oil is a complete toss up. It may burn it or it may not. You will never know unless you ask the previous owner or you buy it and start driving it.
Think about it this way if it does burn a little, what's the big deal if it burns $5 worth of oil in a 5,000 mile oil change. That $5 is cheaper than a complete engine rebuild that may end up doing the exact same thing.
Not in the L9H engine that the silverado/sierra has. It was upgraded to the L94 for the Yukons/Escalade though but wasn't brought to the pick-up trucks.
Changes to the driver's side valve cover and a fitting in the oil pan cured most of the oil usage issues in the AFM equipped trucks.
The pickups used the L9H which does not have AFM from 2009-2013.  The SUVs used the L9H in 2009 and some in 2010.  In 2010 the L9H was "upgraded" to the L94 with AFM and was used from 2010-2014 in the wagons.
Great engines, you'll love the power and torque and ability to use FlexFuels to save money, maybe.
Good call.
Totally forgot about that.
Those trucks are super rare now that I’m thinking about it. Rarely see them at the dealer.
Now it’s 90% Denali Sierras. Crazy how things change. Remember when the z71 Tahoe’s were hot? Lol now if it doesn’t say ‘premier’ people don’t want it
grab it asap, 2009-13 6.2l didn't have afm
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
